HP Business Slim Keyboard with Smart reader
£59.61
40 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Easily connect the keyboard to any USB port on your PC. The included 6 ft (1.8 m) USB cable gives you plenty of room to move the keyboard around your workspace.
  • Enjoy the reassurance of a one-year limited warranty.
  • Get a smart card reader that’s conveniently located in line of sight at the top of the keyboard to help you remember to take your card out. Compatibility with Class A, B, and C smart cards helps prevent hacking and firmware changes in the keyboard.
  • Keep your work environment quiet with lubricated keys, and breathe easy when minor spills happen with the built-in spill drain that makes the keyboard easy to clean.
  • Pair your PC with a sleek, restyled, reduced-size keyboard that packs a familiar layout, function keys, and number pad into a space-saving design. Updated key light indicators alert you when Caps lock, Num lock, and Scroll are on or off.
  • Type: Keyboard
  • Colour: Black
  • Stock Status: In Stock
Product codes
Pair your PC with a sleek, restyled, reduced-size keyboard that packs a familiar layout, function keys, and number pad into a space-saving design. Updated key light indicators alert you when Caps lock, Num lock, and Scroll are on or off. Get a smart card reader that's conveniently located in line of sight at the top of the keyboard to help you remember to take your card out.
Product Description HP Business Slim - keyboard - UK - black
Device Type Keyboard
Interface USB
Connectivity Technology Wired
Localization and Layout UK
Security Devices Smart card reader
Colour Black
Dimensions (WxDxH) 44.06 cm x 14.45 cm x 1.98 cm
Weight 600 g
Manufacturer Warranty 1-year warranty
Designed For EliteDesk 705 G5, 800 G5; EliteOne 800 G5; ProDesk 400 G6, 405 G4, 600 G5; ProOne 400 G5, 440 G5, 600 G5
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Business Slim Keybo...
£59.61
