HP CC06XL (long life) Lithium Ion 6-cell 5100 mAh Battery
£50.83
Delivery:
Product codes
The HP Long Life Battery helps you be productive with your notebook longer than with standard solutions, an industry first, helps lower your cost of ownership significantly.
Construction includes an insulating safety wrap that encloses the cells, a fire-retardant casing, barrier walls that isolate cells from the Printed Circuit Assembly (PCA), and internal connections designed to prevent pinching and potential short circuits.
Product Description HP CC06XL - laptop battery - Li-Ion - 5100 mAh
Device Type Laptop battery
Weight 323 g
Battery Long life - Lithium Ion 6-cell - 5100 mAh
Batteries Qty 1
Dimensions (WxDxH) 4.7 cm x 20.5 cm x 2 cm
Designed For EliteBook 8460p, 8460w, 8560p; Mobile Thin Client 6360t; ProBook 6360b, 6460b, 6465b, 6560b, 6565b
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP CC06XL (long life)...
£50.83
