HP Chromebook 11 G6 Celeron N3350 4GB 16GB 11.6" Chrome...
HP Chromebook 11 G6 Celeron N3350 4GB 16GB 11.6" Chrome OS Education - Touchscreen
£258.62
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Collaborate easily with an optional HD IPS touchscreen and 180° hinge that lies completely flat for efficient group discussions; stay connected in large spaces with 2x2 802.11ac wireless.
  • Give students a Chromebook™ that reinvents rugged. It measures a sleek <19mm thin and has co-molded rubber contact points, a strengthened corner design, durable 180° hinge, and passes MIL-STD 810G testing.
  • Quickly launch apps, support fast web browsing, and get up to a 26% performance improvement with the latest multi-core 7th Gen Intel® processors, memory up to 8 GB, and eMMc storage up to 64 GB.
  • Use the USB-C™ port to access and charge your USB-C™ accessories from your Chromebook™ or charge your Chromebook™ from any USB-C™ adapter.
  • Display Size: 11.6in
  • Processor Model: N3350
  • Operating System: Google Chrome OS 64
  • Installed Memory: 4GB, 4GB
  • Hard Drive Capacity: 16GB
Product codes
Empower students to create, collaborate, and learn with the rugged HP Chromebook 11 EE. Built with co-molded rubber, reinforced corners, and a manageable, secure, and intuitive Chrome OS , it enables access to thousands of educational Android apps and has universal USB-C connectivity and charging.
Product Description HP Chromebook 11 G6 - Education Edition - 11.6" - Celeron N3350 - 4 GB RAM - 16 GB eMMC - UK
Product Type Chromebook
Operating System Google Chrome OS 64 - English
Processor Intel Celeron N3350 / 1.1 GHz (2.4 GHz) / 2 MB Cache /
Memory 4 GB LPDDR4 (provided memory is soldered)
Storage 16 GB - eMMC
Display 11.6" WLED touchscreen 1366 x 768 / HD
Graphics Intel HD Graphics 500
Keyboard UK
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.2
Battery 2-cell - up to 11 hours
Colour Chalkboard grey
Dimensions (WxDxH) 30.6 cm x 20.8 cm x 1.8 cm
Weight 1.24 kg
Localisation Language: English / region: United Kingdom
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - 1 year ¦ Limited warranty - battery - 1 year
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Chromebook 11 G6 Ce...
£258.62
