HP Chromebook 11A G6 AMD A4-9120C 4GB 32GB - Education Edition
£264.34
Delivery:
Key features
  • Enable engaging group discussions with an optional HD IPS touchscreen for easy multi-user views and a 180° hinge that lies flat. Connect in dense settings with 2x2 802.11ac wireless and MIMO.
  • Give students a sleek, rugged <19mm thin Chromebook™ with co-molded rubber contact points, strengthened corners, and a durable 180° hinge. It also undergoes MIL-STD 810G and 70 cm drop testing.
  • Quickly launch apps, support fast web browsing, and efficiently manage battery life with the AMD A4-9120C APU processor, 4 GB memory, and eMMc storage up to 32 GB.
  • Use the USB-C™ port to access and charge your USB-C™ accessories from your Chromebook™ or charge your Chromebook™ from any USB-C™ adapter.
Product codes
Foster creativity, collaboration, and learning with the durable, powerful HP Chromebook 11A G6 EE. Designed with co-molded rubber, reinforced corners, and a manageable, secure, and intuitive Chrome OS™, it enables access to thousands of educational Android™ apps and has universal USB-C™ connectivity and charging.
Product Description HP Chromebook 11A G6 - Education Edition - 11.6" - A4 9120C - 4 GB RAM - 32 GB eMMC - UK
Product Type Chromebook
Operating System Chrome OS 64 - English
Processor AMD A4 9120C / 1.6 GHz (2.4 GHz) / 1 MB Cache
Memory 4 GB DDR4 (provided memory is soldered)
Storage 32 GB - eMMC
Display 11.6" WLED 1366 x 768 / HD
Graphics AMD Radeon R4
Input Device ClickPad
Keyboard UK
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.2
Battery 2-cell - up to 10 hours
Dimensions (WxDxH) 30.6 cm x 20.8 cm x 1.81 cm
Weight 1.28 kg
Localisation Language: English / region: United Kingdom
Environmental Standards TCO Certified Notebooks 8
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Chromebook 11A G6 A...
£264.34
