Get a device engineered for the modern workforce with the versatile HP Chromebook x360 14 G1, our first Chromebook to support up to an Intel Core i7 processor. Be a productivity powerhouse with the fast, simple, and secure Chrome OS , Android apps, and full HD 14" diagonal touchscreen.
Product Description | HP Chromebook x360 14 G1 - 14" - Core i3 8130U - 8 GB RAM - 64 GB eMMC - UK | Product Type | Chromebook - flip design | Operating System | Google Chrome OS 64 | Processor | Intel Core i3 (8th Gen) 8130U / 2.2 GHz (3.4 GHz) / 4 MB Cache | Memory | 8 GB DDR4 (provided memory is soldered) | Storage | 64 GB - eMMC | Display | 14" WLED touchscreen 1920 x 1080 / Full HD | Graphics | Intel UHD Graphics 620 | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2 | Battery | 3-cell | Colour | Sleek metal | Dimensions (WxDxH) | 32.55 cm x 22.7 cm x 1.6 cm | Weight | 1.6 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Warranty | Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year |
General | |
Processor / Chipset | |
CPU | Intel Core i3 (8th Gen) 8130U / 2.2 GHz |
Max Turbo Speed | 3.4 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Rated Speed | 2133 MHz |
Storage | |
Main Storage | 64 GB SSD - (eMMC) |
Display | |
Type | 14" - IPS |
LCD Backlight Technology | WLED backlight |
Touchscreen | Yes |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Brightness | 220 cd/m² |
Features | Full HD ultra wide-viewing angle (UWVA) BrightView eDP, narrow-bezel design |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 620 |
Camera | Yes - HD |
Video Resolutions | 720p |
Sound | Stereo speakers |
Audio Features | Bang & Olufsen Audio |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Multi-touch touchpad, touchpad with gesture support |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 7265 |
Features | Dual stream (2x2) |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 60.9 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt |
Connections & Expansion | |
Interfaces | 2 x USB-C 3.1 Gen 1 (charging) , USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack |
Memory Card Reader | Yes (microSD, microSDHC, microSDXC) |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington nano security slot |
Included Accessories | USB-C power adapter |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.6 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year |
