HP Chromebook x360 G1 Pentium Gold 4415U 4GB 32GB 14" Ch...
HP Chromebook x360 G1 Pentium Gold 4415U 4GB 32GB 14" Chrome OS
£480.62
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Adapt to any setting, project or presentation with a 360° hinge that flips and folds the Chromebook™ into notebook, stand, tent, and tablet modes so you can type, touch, and capture.
  • Power through every task with the boost of an 8th Gen Intel® processor and up to 13 hours battery life. Open and view more apps on the narrow-bezel screen with up to 64 GB storage and 16 GB memory.
  • Set a new style standard with the striking silhouette of a silver, 16 mm-thin Chromebook™ with aluminum cover, diamond-cut touchpad, narrow-bezel touchscreen display, and backlit keyboard.
  • Display Size: 14in
  • Processor Model: 4415U
  • Operating System: Google Chrome OS 64
  • Installed Memory: 8GB
  • Hard Drive Capacity: 32GB
Product codes
Get a device engineered for the modern workforce with the versatile HP Chromebook x360 14 G1, our first Chromebook to support up to an Intel Core i7 processor. Be a productivity powerhouse with the fast, simple, and secure Chrome OS , Android apps, and full HD 14" diagonal touchscreen.
Product Description HP Chromebook x360 14 G1 - 14" - Pentium Gold 4415U - 8 GB RAM - 32 GB eMMC - UK
Product Type Chromebook - flip design
Operating System Google Chrome OS 64
Processor Intel Pentium Gold 4415U / 2.3 GHz / 2 MB Cache
Memory 8 GB DDR4 (provided memory is soldered)
Storage 32 GB - eMMC
Display 14" WLED touchscreen 1920 x 1080 / Full HD
Graphics Intel HD Graphics 610
Keyboard UK
Keyboard Backlight Yes
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.2
Battery 3-cell
Colour Sleek metal
Dimensions (WxDxH) 32.55 cm x 22.7 cm x 1.6 cm
Weight 1.6 kg
Localisation Language: English / region: United Kingdom
Environmental Standards TCO Certified Notebooks 5
Manufacturer Warranty Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Chromebook x360 G1...
£480.62
