We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Get productive MFP performance – world's smallest in-class. Print, scan, copy, and fax, produce high-quality colour results, and print and scan from your phone.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Product Description | HP Color Laser MFP 179fnw - multifunction printer - colour | Device Type | Multifunction printer | Fax Type | Plain paper | Localisation | English, German, French, Italian, Spanish / Europe | Printing Technology | Laser (colour) | Monthly Duty Cycle (max) | 20000 pages | Recommended Monthly Volume | 100 - 500 pages | Max Copying Speed | Up to 14 ppm (mono) / up to 4 ppm (colour) | Max Copying Resolution | Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour) | Max Printing Speed | Up to 18 ppm (mono) / up to 4 ppm (colour) | Max Printing Resolution | Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Fax Resolutions | 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi | Scanning | 600 x 600 dpi | Original Size | A4 (210 x 297 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 40 sheets | Media Size | 76 x 148.5 mm (min) - 216 x 356 mm (max) | Media Type | Labels, recycled paper, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy paper, preprinted paper, coloured paper | Standard Media Capacity | 150 sheets | Output Trays Capacity | 50 sheets | Connection Availability | Yes | Interface | USB 2.0, LAN, Wi-Fi(n) | Office Machine Features | Wireless direct printing, AirPrint ready, Mopria certified, Mobile Printing, scan to PC, Google Cloud Print | Power | AC 230 V (50/60Hz) | Dimensions (WxDxH) | 40.6 cm x 36.3 cm x 34.41 cm | Weight | 14.08 kg | Manufacturer Warranty | 1-year warranty |
General | |
Printing Technology | Laser - colour |
Display | 2 lines |
Display Features | LCD display |
Memory | |
Standard Memory | 128 MB |
Max Supported Memory | 128 MB |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 999 |
Printing | |
First Print Out Time B/W | 12.6 sec |
Scanning | |
Optical Resolution | 600 x 600 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 10-bit |
Fax Machine | |
Max Transmission Speed | 33.6 Kbps |
PC Faxing | Yes |
Fax Machine Features | |
Speed Dialing | 100 station(s) |
Document & Media Handling | |
Max Original Size | A4 (210 x 297 mm) |
Min Media Size | 76 x 148.5 mm |
Max Media Size | A4/Letter |
Min Media Weight | 60 g/m² |
Max Media Weight | 220 g/m² |
Supported Media Type | Labels, recycled paper, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy paper, preprinted paper, coloured paper |
Supported Media Sizes | A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Oficio (216 x 343 mm), 216 x 356 mm |
Document & Media Handling Details | ADF - 40 sheets - A4 (210 x 297 mm) , Input tray - 150 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 50 sheets |
Speed Details | Printing: up to 18 ppm (A4) - B/W (ISO) , Printing: up to 4 ppm (A4) - colour (ISO) , Copying: up to 18 ppm (A4) - B/W normal , Copying: up to 4 ppm (A4) - colour normal |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN |
Power | |
Voltage Required | AC 230 V (50/60Hz) |
Power Consumption Operational | 300 Watt |
Power Consumption Standby | 38 Watt |
Power Consumption Sleep | 1.9 Watt |
Miscellaneous | |
Consumables Included | 1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 700 pages , 1 x toner cartridge (magenta) - up to 700 pages , 1 x toner cartridge (yellow) - up to 700 pages |
Compliant Standards | DEMKO, FIMKO, GS, NEMKO, SEMKO, ANSI C63.4-2009, CECP, IPv6 Ready, EN 62479:2010, CNS 13438, Blue Angel Ecolabel, EN 61000-3-3:2013, EN 55024:2010, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, ICES-003 issue 5, KN32, KN35, EN 55032:2012, IEC/EN 60825-1:2014 Class 1, CISPR 32:2012, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight | |
Width | 40.6 cm |
Depth | 36.3 cm |
Height | 34.41 cm |
Weight | 14.08 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 50.1 cm |
Shipping Depth | 46.6 cm |
Shipping Height | 44 cm |
Shipping Weight | 17.38 kg |
Environmental Parameters | |
Min Operating Temperature | 15 °C |
Max Operating Temperature | 27 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
