Get productive print performance – world's smallest colour laser in it's class. Print, and scan, produce high-quality colour results, and print and scan from your phone.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Product Description | HP Color Laser 150nw - printer - colour - laser | Printer Type | Workgroup printer - laser - colour | Number of Users | 1-5 users | Weight | 10.04 kg | Localisation | English, German, French, Italian, Spanish / Europe | Media Size Class | A4/Legal | Max Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) | Min Media Size (Custom) | 76 mm x 127 mm | Max Media Size (Custom) | 216 mm x 356 mm | Print Speed | Up to 19 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 4 ppm - color (ISO) - A4 (210 x 297 mm) | Max Resolution (B&W) | 600 x 600 dpi | Max Resolution (Colour) | 600 x 600 dpi | Interface | USB 2.0, LAN, Wi-Fi(n) | AirPrint Enabled | Yes | Processor | 400 MHz | RAM Installed (Max) | 64 MB (64 MB) | Language Simulation | SPL (Samsung Printer Language) | Media Type | Envelopes, transparencies, labels, plain paper, cards, recycled paper, glossy paper | Total Media Capacity | 150 sheets | Monthly Duty Cycle (max) | 20000 pages | Recommended Monthly Volume | 100 - 500 pages | Networking | Print server | Printer Features | Wireless Direct Print, Rendering Engine for Clean Page (ReCP) Technology, Mopria certified, Auto Power Off | System Requirements | Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Apple MacOS X 10.3, Apple MacOS X 10.2.8, Apple MacOS X 10.4, Apple MacOS X 10.4 or later, Microsoft Windows Vista | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 38.2 cm x 30.9 cm x 21.15 cm |
General | |
Printer | |
Built-in Devices | Status LCD |
Connectivity Technology | Wired |
PostScript Support | Standard |
Processor | |
RAM | |
RAM Installed (Max) | 64 MB / 64 MB (max) |
Media Handling | |
Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm) |
Media Weight | 60 g/m² - 220 g/m² |
Output Trays Capacity | 50 sheets |
Duty Cycle | |
Networking | |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 |
Miscellaneous | |
Consumables Included | 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow) |
Features | Mercury free |
Compliant Standards | Plug and Play, UL, cUL, GS, ANSI C63.4-2009, CECP, GB 9254-2008, EN 62479:2010, CNS 13438, LVD 2006/95/EC, GB 17625.1-2012, EN 61000-3-3:2013, CoC, EN 55024:2010, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, ICES-003 issue 5, KN32, KN35, EN 55032:2012+AC:2013 Class A, CAN/CSA C22.2 No. 60950-1-07 Second Edition 2014-10, IEC/EN 60825-1:2014 Class 1, CISPR 32:2012, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 |
Power | |
Power Device | Power supply - internal |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 282 Watt |
Power Consumption Stand by | 27 Watt |
Power Consumption Sleep | 1 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Apple MacOS X 10.3, Apple MacOS X 10.2.8, Apple MacOS X 10.4, Apple MacOS X 10.4 or later, Microsoft Windows Vista |
Environmental Standards | |
Blue Angel | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 30 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
Dimensions & Weight | |
Width | 38.2 cm |
Depth | 30.9 cm |
Height | 21.15 cm |
Weight | 10.04 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 47.1 cm |
Depth (Shipping) | 41.3 cm |
Height (Shipping) | 30.5 cm |
Weight (Shipping) | 12.52 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
