General |
Device Type |
Multifunction printer |
Fax Type |
Plain paper |
Printing Technology |
Laser - colour |
Monthly Duty Cycle (max) |
200000 pages |
Recommended Monthly Volume |
5000 - 25000 pages |
Display Diagonal Size |
8" |
Display Features |
Touch screen |
Connection Availability |
Yes |
Interface |
USB 2.0, Gigabit LAN, USB host, USB host (internal) |
Office Machine Features |
Save to USB flash drive, scan to e-mail, save to network folder, HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, scan to Cloud, HP EasyColor, Instant-on Technology |
Localisation |
English, German, French, Italian, Spanish / Europe |
Memory |
Standard Memory |
1.5 GB |
Hard Disk Drive |
320 GB |
Copying |
Max Document Enlargement |
400% |
Max Document Reduction |
25% |
Automatic Duplexing |
Yes |
Copying Features |
Edge Erase |
Printing |
Max Printing Resolution |
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour) |
Max Printing Speed |
Up to 46 ppm (mono) / up to 46 ppm (colour) |
Printer Drivers / Emulations |
PCL 5e, PCL 6, PostScript 3, PDF 1.4 |
Image Enhancement Technology |
HP FastRes 1200, HP ImageREt 4800, HP ProRes 1200 |
Yes |
First Print Out Time B/W |
11 sec |
Scanning |
Yes |
Optical Resolution |
600 dpi |
Fax Machine |
Max Transmission Speed |
33.6 Kbps |
Fax Resolutions |
300 x 300 dpi, 200 x 100 dpi |
Fax Machine Features |
Speed Dialing |
100 station(s) |
Broadcast Transmission |
100 stations |
Features |
Fax forwarding, automatic redialing, auto reduction, fax polling |
Document & Media Handling |
Max Original Size |
A3 (297 x 420 mm), Ledger (279 x 432 mm) |
Original Type |
Sheets |
Document Feeder Capacity |
200 sheets |
Min Media Size |
76 x 127 mm |
Max Media Size |
A3/Ledger |
Min Media Weight |
60 g/m² |
Max Media Weight |
220 g/m² |
Supported Media Type |
Transparencies, plain paper, labels, recycled paper, bond paper, card stock |
Supported Media Sizes |
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ARCH B (304.8 x 457.2 mm), JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), SRA3 (320 x 450 mm), SRA4 (225 x 320 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 197 x 273 mm, 76.2 x 127 mm, RA3 (305 x 430 mm), 127 x 177.8 mm, 279.4 x 431.8 mm, 215.9 x 330.2 mm, 127 x 203.2 mm, JIS B6 (128 x 182 mm), RA4 (215 x 305 mm), 270 x 390 mm, 260 x 368 mm, 273 x 394 mm, 195 x 270 mm, 184 x 260 mm |
Supported Envelope Sizes |
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm) |
Standard Media Capacity |
2100 sheets |
Bypass Feeder Capacity |
100 sheets |
Output Trays Capacity |
500 sheets |
Document & Media Handling Details |
ADF - 200 sheets - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 199 g/m² , Input tray - 100 sheets size: 76 x 127 mm - 320 x 470 mm weight: 60 g/m² - 220 g/m² , 4 x input tray - 500 sheets size: 148 x 210 mm - 297 x 431.8 mm weight: 60 g/m² - 199 g/m² , Output tray - 500 sheets |
Speed Details |
Printing: up to 46 ppm (A4) - B/W normal , Printing: up to 46 ppm (A4) - colour , Printing: up to 22 ppm (A3) - B/W , Printing: up to 22 ppm (A3) - colour , Scanning: up to 70 ppm (A4) - B/W , Scanning: up to 85 ipm (A4) - B/W duplex , Scanning: up to 68 ppm (A4) - colour , Scanning: up to 63 ipm (A4) - colour duplex |
Connections |
Interfaces |
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 2 x USB host (internal) , 1 x Gigabit LAN - RJ-45 |
Security Protocols & Features |
LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, AES-256 |
Operating System Support |
MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, MS Windows Server 2003 SP2 or later, MS Windows Server 2003 x64 Edition SP2 or later |
Software Included |
Drivers & Utilities |
Power |
Voltage Required |
AC 230 V (50Hz) |
Power Consumption Operational |
1100 Watt |
Power Consumption Standby |
80 Watt |
Power Consumption Sleep |
8 Watt |
Miscellaneous |
First Copy Out Time B/W |
12 sec |
Included Accessories |
Phone cable |
Consumables Included |
1 x Cartridge (black) - up to 29500 pages , 1 x Cartridge (cyan) - up to 32000 pages , 1 x Cartridge (magenta) - up to 32000 pages , 1 x Cartridge (yellow) - up to 32000 pages |
Compliant Standards |
UL, CISPR 22 Class A, cUL, EN 61000-3-2, GS, ICES-003, EN 61000-3-3, EN55024, FCC Part 68 / CS03 Issue 8, EMC, R&TTE, FCC CFR47 Part 15, IEC 60950-1, IEC 60825-1, GB 17625.1-2003 EMC, IEC 62479 |
Environmental Standards |
EPEAT Compliant |
EPEAT Silver |
ENERGY STAR Certified |
Yes |
Blue Angel Compliant |
Yes |
Dimensions & Weight |
Width |
70.4 cm |
Depth |
63.5 cm |
Height |
119.9 cm |
Weight |
150.6 kg |
Dimensions & Weight (Shipping) |
Shipping Weight |
173.3 kg |
Environmental Parameters |
Sound Emission |
33 dBA (idle) / 55 dBA (operating) |
Min Operating Temperature |
15 °C |
Max Operating Temperature |
30 °C |
Humidity Range Operating |
10 - 80% |
