HP Colour LaserJet Managed Flow MFP M880zm+ Printer
Key features
  • Intuitive 8-inch (20.3 cm) HP Easy Select pivoting color touchscreen control panel
  • 200-sheet automatic document feeder with single pass two-sided scanning, and HP EveryPage with ultrasonic double-feed detection
  • Home button (returns to home screen)
  • Plate glass color scanner handles sizes up to 11 x 17 in/A3
  • Easy-access USB port to save and print files directly
  • Hardware integration pocket for solution integration
  • 500-sheet output bin
  • Front door provides convenient access to HP toner cartridges and drums
  • Built-in automatic two-sided printing
  • Retractable keyboard for easy, accurate data entry
  • 100-sheet multipurpose tray handles heavy custom media up to 58 lb bond
  • Right-side doors provide access to the fuser and for clearing jams
  • 500-sheet input tray supports media up to size 11 x 17 in/A3
  • 3,500-sheet high-capacity input tray supports media sizes letter/A4
  • HP Jetdirect Gigabit Ethernet print server
  • HP high-performance secure hard disk
  • Access port for optional Kensington-style lock
  • Hi-Speed USB 2.0 port (for connecting third-party devices)
  • Hi-Speed USB 2.0 printing port
  • 800 MHz processor, 2.5 GB (system memory)
  • Foreign interface harness (for connecting external devices)
  • Two internal host USB 2.0 type ports for third party solutions
  • RJ-11 fax port
Product codes
PC Connection Gigabit LAN, USB 2.0 host, USB 2.0, USB 2.0 host (internal)
Printing Output Type Colour
Type of Machine Fax / copier / printer / scanner
  • RJ-11 fax port
HP Color LaserJet Managed Flow MFP M880zm+ - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
300000 pages
Recommended Monthly Volume
5000 - 50000 pages
Max Copying Speed
Up to 46 ppm (mono) / up to 46 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi, 100 x 100 dpi
Scanning
600 dpi
Display
8"
Original Size
147 x 68 mm (min) - A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
200 sheets
Media Size
76.2 x 127 mm (min) - 320 x 457.2 mm (max)
Media Type
Transparencies, envelopes, plain paper, labels, photo paper, film, glossy paper
Standard Media Capacity
4100 sheets
Max Media Capacity
4100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Stacker
Optional
Stapler
Optional
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB 2.0 host, USB 2.0 host (internal)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to network, Hardware Integration Pocket, Foreign Interface Harness (FIH), HP High-Performance Secure Hard Disk, pull-out keyboard
AC 230 V (50Hz)
70.4 cm x 63.5 cm x 119.9 cm
152.9 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Colour LaserJet Man...
