HP Colour Laserjet Pro M479fdn Multifunction Printer
£332.58
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • A suite of embedded security features help protect your MFP from being an entry point for attacks.
  • Avoid frustrating reprints, wasted supplies, and service calls using Original HP toner cartridges.
  • Scan files directly to local Microsoft SharePoint, email, USB, and network folders.
  • Set up this MFP fast, and easily manage device settings to help increase overall printing efficiency.
  • Type: Fax / copier / printer / scanner
  • Functionality: Copier, Fax, Printer, Scanner
  • Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
  • Stock Status: In Stock
Product codes
Winning in business means working smarter. The HP Color LaserJet Pro MFP M479 is designed to let you focus your time where it's most effective-growing your business and staying ahead of the competition.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
Product Description HP Color LaserJet Pro MFP M479fdn - multifunction printer - colour
Device Type Multifunction printer
Fax Type Plain paper
Localisation English, German, French, Italian, Spanish / Europe
Printing Technology Laser (colour)
Monthly Duty Cycle (max) 50000 pages
Recommended Monthly Volume 750 - 4000 pages
Max Copying Speed Up to 27 ppm (mono) / up to 27 ppm (colour)
Max Copying Resolution Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed Up to 27 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution Up to 38400 x 600 dpi (mono) / up to 38400 x 600 dpi (colour)
Max Fax Transmission Speed 33.6 Kbps
Fax Resolutions 203 x 196 dpi, 300 x 300 dpi, 203 x 96 dpi
Scanning 1200 x 1200 dpi
Display 4.3"
Original Size 102 x 152 mm (min) - Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, glossy paper
Standard Media Capacity 300 sheets
Max Media Capacity 850 sheets
Bypass Feeder Capacity 50 sheets
Output Trays Capacity 150 sheets
Automatic Duplexing Yes (copying) Yes (printing) Yes (scanning)
Connection Availability Yes
Interface USB 2.0, LAN, USB host
AirPrint Enabled Yes
Office Machine Features Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, scan to Cloud, Mopria certified
Power AC 220 V (50/60Hz)
Dimensions (WxDxH) 41.6 cm x 47.2 cm x 40 cm
Weight 23.4 kg
Environmental Standards ENERGY STAR Qualified, Blue Angel
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Colour Laserjet Pro...
£332.58
