EE + BT. BETTER AS ONE. WE’RE PART OF THE SAME FAMILY.
HP Colour Laserjet Pro MFP M479DW
FREE DELIVERY
£379.34
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Scan files directly to Microsoft SharePoint , email, USB, and network folders.
  • A suite of embedded security features help protect your MFP from being an entry point for attacks.
  • Set up this MFP fast, and easily manage device settings to help increase overall printing efficiency.
  • Avoid frustrating reprints, wasted supplies, and service calls using Original HP toner cartridges.
  • Type: Printer / copier / scanner
  • Functionality: Scanner, Copier, Printer
  • Max Paper Size: Legal (216 x 356 mm), A4 (210 x 297 mm)
Product codes
Winning in business means working smarter. The HP Color LaserJet Pro MFP M479 is designed to let you focus your time where it's most effective-growing your business and staying ahead of the competition.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Product Description HP Color LaserJet Pro MFP M479dw - multifunction printer - colour
Device Type Multifunction printer
Localisation English, German, French, Italian, Spanish / Europe
Printing Technology Laser (colour)
Monthly Duty Cycle (max) 50000 pages
Recommended Monthly Volume 750 - 4000 pages
Max Copying Speed Up to 27 ppm (mono) / up to 27 ppm (colour)
Max Copying Resolution Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed Up to 27 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution Up to 38400 x 600 dpi (mono) / up to 38400 x 600 dpi (colour)
Scanning 1200 x 1200 dpi
Display 4.3"
Original Size 102 x 152 mm (min) - Legal (216 x 356 mm) (max)
Original Type Sheets
Document Feeder Capacity 50 sheets
Media Size 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, glossy paper
Standard Media Capacity 300 sheets
Max Media Capacity 850 sheets
Bypass Feeder Capacity 50 sheets
Output Trays Capacity 150 sheets
Automatic Duplexing Yes (printing)
Connection Availability Yes
Interface USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled Yes
Office Machine Features Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, scan to Cloud
Power AC 220 V (50/60Hz)
Dimensions (WxDxH) 41.6 cm x 47.2 cm x 40 cm
Weight 23.3 kg
Environmental Standards ENERGY STAR Qualified, Blue Angel
Manufacturer Warranty 1-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£379.34
