HP Conferencing Keyboard
£36.43
Delivery:
Standard: 1-3 working days
Key features
  • Conduct virtual meetings and calls with Microsoft Lync 2013.
  • Connect through USB and get a full-sized quiet keyboard with intuitive, dedicated, illuminated keys for call functions and screen or video sharing. LEDs cue when you’re on mute, sharing your screen, or your video is off during video calls.
  • Get the reassurance of a one-year limited warranty.
  • Type: Keyboard
  • Wired / Wireless: Wired
  • Compatibility: PC
  • Stock Status: In Stock
Product codes
Drive your Microsoft Lync voice and video calls directly from your HP Conferencing Keyboard and connect, disconnect, and manage your calls and videoconferencing settings with simple dedicated keys.
Product Description HP Conferencing - keyboard - UK
Device Type Keyboard
Interface USB
Layout UK
Keys Qty 111
Hot Keys Function Volume, mute, answer call, end/reject call
Features Status LED indicator, 12 function keys
Dimensions (WxDxH) 44.05 cm x 15.5 cm x 2.16 cm
Weight 700 g
Manufacturer Warranty 1-year warranty
Designed For HP 245 G7, 25X G7, 34X G5; Elite Slice G2; EliteBook 10XX G1, 735 G6, 745 G6, 830 G6, 840 G6, 840r G4, 850 G6; EliteBook x360; EliteDesk 800 G4; Mobile Thin Client mt45; ProBook 430 G6, 445r G6, 44X G6, 455r G6, 45X G6, 640 G5, 650 G5; ProBook x360; Spectre x360; ZBook 14u G6, 15 G6, 15u G6, 17 G6
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£36.43
