HP DesignJet T250 Large-Format Printer
FREE DELIVERY
£952.09
13 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Save time with the world's easiest job submission—send multiple files in one click with HP Click.
  • Save space with the world's smallest plotters designed to fit your office.
  • Avoid waiting by the printer with high-speed printing as fast as 30 seconds per A1 plot.
  • Type: Printer
  • Functionality: Printer
  • Wireless Capability: Wireless, Wired
  • Max Paper Size: A1 (594 x 841 mm), ANSI D (559 x 864 mm)
Product codes
Designed to fit your office, budget, and the way you work, the world's smallest plotters provide outstanding simplicity. Send multiple files in just one click. Print your A1 plot as fast as 30 seconds. 500 MB memory.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Product Description HP DesignJet T250 - large-format printer - colour - ink-jet
Printer Type 24" large-format printer - ink-jet - colour
Weight 21.5 kg
Localisation English, German, French, Italian, Spanish / Europe
Inkjet Technology HP Thermal Inkjet
Ink Palette Supported (Colours) 4-ink - cyan, magenta, yellow, pigment black
Max Media Size A1 (594 x 841 mm), ANSI D (559 x 864 mm)
Min Media Size (Custom) 210 mm x 279 mm
Max Media Size (Custom) 610 mm x 45.7 m
Print Speed Up to 0.5 min/page - black draft - ANSI D (559 x 864 mm) , Up to 0.5 min/page - colour draft - ANSI D (559 x 864 mm) , Up to 0.5 min/page - black draft - A1 (594 x 841 mm) , Up to 0.5 min/page - colour draft - A1 (594 x 841 mm)
Max Resolution (B&W) 2400 x 1200 dpi
Max Resolution (Colour) 2400 x 1200 dpi
Interface USB 2.0, LAN, Wi-Fi
RAM Installed (Max) 512 MB (512 MB)
Language Simulation URF, JPEG
Media Type Plain paper, photo paper, bond paper, film, glossy paper, semi-gloss paper, technical paper, self-adhesive paper
Networking Print server
Printer Features Print from mobile device, 4.1 kg max roll weight
Environmental Standards EPEAT Gold
Dimensions (WxDxH) 101.3 cm x 44 cm x 28.5 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£952.09
