The world's smallest wide-format printer with a built-in stand, is designed to fit your office, budget, and the way you work. Print multi-size projects with ease. Print your A1 plot as fast as 30 seconds. 1 GB memory.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Product Description | HP DesignJet T630 - large-format printer - colour - ink-jet | Printer Type | 36" large-format printer - ink-jet - colour | Weight | 34.7 kg | Localisation | English, German, French, Italian, Spanish / Europe | Inkjet Technology | HP Thermal Inkjet | Ink Palette Supported (Colours) | 4-ink - cyan, magenta, yellow, pigment black | Max Media Size | A0 (841 x 1189 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m) | Min Media Size (Custom) | 210 mm x 279 mm | Max Media Size (Custom) | 914 mm x 45.7 m | Print Speed | Up to 0.5 min/page - black draft - ANSI D (559 x 864 mm) , Up to 0.5 min/page - colour draft - ANSI D (559 x 864 mm) , Up to 0.5 min/page - black draft - A1 (594 x 841 mm) , Up to 0.5 min/page - colour draft - A1 (594 x 841 mm) | Max Resolution (B&W) | 2400 x 1200 dpi | Max Resolution (Colour) | 2400 x 1200 dpi | Interface | USB 2.0, LAN, Wi-Fi | RAM Installed (Max) | 1 GB (1 GB) | Language Simulation | HP RTL, CALS G4, HP GL/2, URF, JPEG | Media Type | Plain paper, photo paper, bond paper, recycled paper, film, glossy paper | Networking | Print server | Printer Features | Print from mobile device, 6.2 kg max roll weight | Environmental Standards | EPEAT Gold | Manufacturer Warranty | 1-year warranty | Dimensions (WxDxH) | 131.7 cm x 60.5 cm x 93.2 cm |
General | |
Printer | |
Nozzle Configuration | 1376 nozzles |
Minimum Ink Droplet Size | 12 pl (black), 5.5 pl (colour) |
Ink Cartridge Configuration | 4 cartridges (1 each: cyan, magenta, yellow, pigment black) |
Connectivity Technology | Wireless |
RAM | |
RAM Installed (Max) | 1 GB / 1 GB (max) |
Media Handling | |
Media Sizes | A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m) |
Media Thickness Range | Up to 0.3 mm |
Media Weight | 60 g/m² - 280 g/m² |
Networking | |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 |
Miscellaneous | |
Compliant Standards | FCC Class B certified, CSA, ICES Class B, WEEE, ERP |
Power | |
Power Device | Power supply - internal |
Frequency Required | 50/60 Hz |
Power Consumption Operational | 35 Watt |
Power Consumption Stand by | 0.2 Watt |
Power Consumption Sleep | 2.1 Watt |
Software / System Requirements | |
Software Included | HP Support Assistant, HP Click, HP DesignJet Utility |
Environmental Standards | |
EPEAT Compliant | EPEAT Gold |
ENERGY STAR | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts - 1 year |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
Sound Emission (Idle) | 16 dBA |
Sound Emission (Operating) | 42 dBA |
Dimensions & Weight | |
Width | 131.7 cm |
Depth | 60.5 cm |
Height | 93.2 cm |
Weight | 34.7 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 147 cm |
Depth (Shipping) | 57.5 cm |
Height (Shipping) | 59 cm |
Weight (Shipping) | 55.3 kg |
