HP DesignJet T730 36" Colour InkJet Printer
£2,241.99
Delivery:
Key features
  • Cut waste by 50% – print at half scale with automatic sheet feeder/tray; cut extra work, waste of wide rolls.
  • Print from mobile devices in a few simple clicks with HP Mobile Printing – quickly work through revisions.
  • Robust, compact, and professional – this printer fits your business and gives you space to work.
  • Type: Printer
  • Functionality: Printer
  • Output Type: Colour
  • Wireless Capability: Wired, Wireless
  • Technology: Ink-jet
Product codes
A smart investment for architects, engineers, and construction professionals, this robust, compact 91.4-cm printer easily fits your business. You can reduce time/waste with convenient features. Print conveniently on-the-go with HP Mobile Printing.
Product Description HP DesignJet T730 - large-format printer - colour - ink-jet
Printer Type 36" large-format printer - ink-jet - colour
Weight 48 kg
Localisation English, German, French, Italian, Spanish / Europe
Inkjet Technology HP Thermal Inkjet
Ink Palette Supported (Colours) 4-ink - cyan, magenta, yellow, pigment black
Max Media Size Roll (91.4 cm x 45.7 m)
Min Media Size (Custom) 210 mm x 279 mm
Max Media Size (Custom) 914 mm x 45.7 m
Print Speed Up to 1.36 ppm - draft - ANSI D (559 x 864 mm)
Max Resolution (B&W) 2400 x 1200 dpi
Max Resolution (Colour) 2400 x 1200 dpi
Interface Gigabit LAN, Wi-Fi, USB 2.0 host
AirPrint Enabled Yes
RAM Installed (Max) 1 GB
Language Simulation PCL 3, HP RTL, CALS G4, HP GL/2, TIFF, PDF 1.7, URF
Media Type Plain paper, photo paper, tracing paper, glossy photo paper, matt photo paper, bond paper, film, backlit paper, translucent bond paper, self-adhesive paper, coated paper, heavy-weight coated paper, semi-gloss photo paper, high-gloss photo paper, matte film, vellum paper, polyester film, self-adhesive vinyl, satin photo paper
Total Media Capacity 1 roll
Printer Features Print from mobile device
Power AC 120/230 V
System Requirements Apple MacOS, Microsoft Windows, Windows 8
Dimensions (WxDxH) 140.3 cm x 58.3 cm x 115.5 cm
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP DesignJet T730 36"...
£2,241.99
