General |
Printer Type |
36" large-format printer - ink-jet - colour |
Localisation |
English, German, French, Italian, Spanish / Europe |
Printer |
Inkjet Technology |
HP Thermal Inkjet |
Ink Palette Supported (Colours) |
4-ink - cyan, magenta, yellow, pigment black |
Nozzle Configuration |
1376 nozzles |
Minimum Ink Droplet Size |
12.6 pl (black), 6 pl (colour) |
Ink Cartridge Configuration |
4 cartridges (1 each: cyan, magenta, yellow, black) |
Print Speed |
Up to 1.36 ppm - draft - ANSI D (559 x 864 mm) |
Built-in Devices |
Cutter |
Connectivity Technology |
Wireless |
Interface |
Gigabit LAN, Wi-Fi, USB 2.0 host |
AirPrint Enabled |
Yes |
Max Resolution (B&W) |
2400 x 1200 dpi |
Max Resolution (Colour) |
2400 x 1200 dpi |
Language Simulation |
PCL 3, HP RTL, CALS G4, HP GL/2, TIFF, PDF 1.7, URF |
Printer Features |
Print from mobile device |
RAM |
RAM Installed (Max) |
1 GB |
Media Handling |
Media Type |
Plain paper, photo paper, tracing paper, glossy photo paper, matt photo paper, bond paper, film, backlit paper, translucent bond paper, self-adhesive paper, coated paper, heavy-weight coated paper, semi-gloss photo paper, high-gloss photo paper, matte film, vellum paper, polyester film, self-adhesive vinyl, satin photo paper |
Max Media Size |
Roll (91.4 cm x 45.7 m) |
Min Media Size (Custom) |
210 mm x 279 mm |
Max Media Size (Custom) |
914 mm x 45.7 m |
Media Sizes |
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), Roll (91.4 cm x 45.7 m), 210 x 279 mm, 210 x 914 mm, 914 x 1879 mm |
Total Media Capacity |
1 roll |
Media Feeders |
1 x manual - 1 roll - Roll (91.4 cm x 45.7 m) |
Networking |
Security Protocols & Features |
Wi-Fi Direct |
Expansion / Connectivity |
Connections |
1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A |
Miscellaneous |
Included Accessories |
Media bin, stand, spindles |
Consumables Included |
1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (black) |
Compliant Standards |
CSA, VCCI, GOST, CCC, PSB, FCC, IRAM, RoHS, EN 60950-1, KCC, WEEE, ICES, REACH, FSC, LVD, EuP, EMC Class B, PEFC, IPv6 Ready, China RoHS, ACMA |
Power |
Power Device |
Power supply - internal |
Voltage Required |
AC 120/230 V |
Frequency Required |
50/60 Hz |
Power Consumption Operational |
35 Watt |
Power Consumption Sleep |
3.5 Watt |
Software / System Requirements |
Software Included |
Drivers & Utilities |
OS Required |
Apple MacOS, Microsoft Windows, Windows 8 |
Environmental Standards |
ENERGY STAR |
Yes |
Environmental Parameters |
Min Operating Temperature |
5 °C |
Max Operating Temperature |
40 °C |
Humidity Range Operating |
20 - 80% |
Sound Emission (Operating) |
48 dBA |
Dimensions & Weight |
Width |
140.3 cm |
Depth |
58.3 cm |
Height |
115.5 cm |
Weight |
48 kg |
Dimensions & Weight (Shipping) |
Width (Shipping) |
157.8 cm |
Depth (Shipping) |
57.5 cm |
Height (Shipping) |
64.6 cm |
Weight (Shipping) |
70 kg |
