HP DesignJet Z2100 44" A0 Large Format Printer
Key features
  • Generate custom ICC profiles and achieve color accuracy, consistency with the embedded spectrophotometer.
  • Optimize performance, ink usage—automatic servicing routines help prevent nozzle clogging, reduce media waste.
  • Produce vivid, high-quality color and black-and-white prints that impress your customers.
Product codes
HP's 8-ink Designjet delivers superior colour accuracy and consistency with the first-ever embedded spectrophotometer. Produce vivid, large format prints (up to 610 mm or 1118mm) in colour or black-and-white with 8 Original HP Photo Inks.
Product Description HP DesignJet Z2100 - large-format printer - colour - ink-jet
Printer Type 44" large-format printer - ink-jet - colour
Form Factor Stationary
Weight 86 kg
Localisation English, German, French, Italian, Spanish / Europe
Ink Palette Supported (Colours) 8-ink
Max Media Size Roll (111.8 cm x 91.4 m)
Max Media Size (Custom) 1117 mm
Print Speed Up to 2 min/page - colour draft , Up to 4.2 min/page - colour normal , Up to 9.8 min/page - colour best
Max Resolution (B&W) 2400 x 1200 dpi
Max Resolution (Colour) 2400 x 1200 dpi
Interface USB, LAN
RAM Installed (Max) 128 MB
Hard Drive 80 GB
Language Simulation PCL 3
Media Type Glossy photo paper, matt photo paper, bond paper, matte proofing paper, semi-gloss proofing paper, backlit paper, high-gloss proofing paper, coated paper, heavy-weight coated paper, semi-gloss photo paper, self-adhesive vinyl, satin photo paper
Networking Print server - Ethernet, Fast Ethernet
Power AC 120/230 V
System Requirements Apple MacOS X 10.2, Microsoft Windows 2000 / XP, Apple MacOS X 10.3, Apple MacOS X 10.4 or later
Microsoft Certification Compatible with Windows 7
Manufacturer Warranty 1-year warranty
Dimensions (WxDxH) 177 cm x 69 cm x 104.7 cm
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP DesignJet Z2100 44"...
