HP DesignJet Z6200 42" Large Format Printer
£8,669.12
Delivery:
Key features
  • Do more—produce backlit signs, POP displays, roll-up banners, canvases, line drawings, and maps with unrivalled print quality
  • Print as fast as 113 m²/hr (1225 ft²/hr) in Fast mode and 16.4 m²/hr (177 ft²/hr) in Normal mode
  • See reliable results with HP Professional PANTONE® color emulation and Adobe Postscript®/PDF Upgrade Kit
Product codes
No need to make trade-offs with this, the fastest printer in its class. The HP DesignJet Z6200 Photo Production Printer-a workhorse in disguise-enables you to offer outstanding photo image quality. Become a trusted partner with HP technologies.
Designed for speed and productivity
Create quality prints at top speed with HP Double Swath Technology and the HP Optical Media Advance Sensor
Gain time—you can handle all your prints immediately using fastdrying HP Vivid Photo Inks
Unrivalled image quality
Create unique black-and-white prints—three shades of black HP inks produce outstanding optical density and smooth transitions
Offer exceptional colors—HP Vivid Photo Inks include chromatic red for a wide color gamut, with uniform gloss
Advanced color management backed by HP reliability
Generate custom ICC profiles and achieve color accuracy, consistency with the embedded spectrophotometer
Boost color accuracy—complete coverage of SWOP, ISO, GRACOL, 3DAP, EUROSCALE, TOYO, and FOGRA gamut
HP DesignJet Z6200 - large-format printer - colour - ink-jet
Printer Type
42" large-format printer - ink-jet - colour
123 kg
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
Light cyan, magenta, light magenta, yellow, red, green, blue, light grey, grey, photo black, matte black, gloss enhancer
Min Media Size (Custom)
280 mm
Max Media Size (Custom)
1067 mm
Print Speed
Up to 140 sq.m/hour - mixed text/colour graphics draft
Max Resolution (B&W)
2400 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
USB, Gigabit LAN
Hard Drive
160 GB
Language Simulation
HP RTL, CALS G4, HP GL/2
Media Type
Coated paper, photo paper, fabric, bond paper, proofing paper, banner paper, film, backlit paper
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
AC 120/230 V
Linux, Microsoft Windows, Microsoft Windows 7, Apple MacOS X 10.6, Apple MacOS X 10.5
Microsoft Certification
Compatible with Windows 7
1 year warranty
197 cm x 69 cm x 137 cm
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP DesignJet Z6200 42"...
£8,669.12
