HP Deskjet 2710e All-in-One Multifunction printer
FREE DELIVERY
NEVER RUN OUT OF INK WITH INSTANT INK
£49.99
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
Key features
  • Get started fast with simple setup that guides you through each step, using HP Smart app.
  • Get better range and faster, more reliable connections using dual-band Wi-Fi with self-reset.
  • Never run out of ink. Convenient ink cartridge replacements and smart delivery included.
  • A cloud-connected HP+ printer is smarter – it keeps itself up to date and ready to print.
  • Type: Printer / copier / scanner
  • Functionality: Scanner, Copier, Printer
  • Output Type: Colour
  • Wireless Capability: Wireless
  • Technology: Deskjet
Product codes
Simple setup. Simple printing.
Get started fast with simple setup that guides you through each step, using HP Smart app. Easily handle tasks and get a lot from one device – print, scan, and copy. Get quick and easy printing directly at the control panel. Easily print, scan, and copy everyday documents from your smartphone, using HP Smart app.
Worry-free wireless
Get better range and faster, more reliable connections using dual-band Wi-Fi® with self-reset.Get connected with Bluetooth® and start printing fast from your smartphone or tablet – easy setup.Built-in wireless capabilities let you easily access, print, and share resources on a network
Never run out of ink with Instant Ink
Never run out of ink.Convenient ink cartridge replacements and smart delivery included. Save up to 70% with Instant Ink. Enroll to get ink, delivery and recycling starting at £0.99 a month. Peace of mind with plan flexibility to change or cancel anytime at no cost. Help us put plastic back into printers with prepaid recycling service included
HP+. HP's smart printing system.
A cloud-connected HP+ printer is smarter – it keeps itself up to date and ready to print. First 6 months of Instant Ink included; after 6 months, monthly fee charged automatically unless cancelled. Print and scan from the palm of your hand. Enjoy advanced productivity features for 2 years with HP+. HP+ requires an HP account, ongoing internet connection, and use of Original HP ink cartridges.
  • Print, copy, scan
  • Colour
  • 10 x 15 cm; A4; Envelopes
  • Print speed up to 7.5 ppm (black) and 5.5 ppm (colour)
  • Wireless; HP+; HP Instant Ink eligible; Print from phone or tablet
  • For teams up to 3 users; Prints up to 100 pages/month
Product Description HP Deskjet 2710e All-in-One - multifunction printer - colour - HP Instant Ink eligible
Device Type Multifunction printer
Printing Technology Ink-jet (colour)
Inkjet Technology HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max) 1000 pages
Recommended Monthly Volume 50 - 100 pages
Max Copying Speed Up to 6 ppm (mono) / up to 3 ppm (colour)
Max Copying Resolution Up to 300 x 300 dpi (mono) / up to 300 x 300 dpi (colour)
Max Printing Speed Up to 7.5 ppm (mono) / up to 5.5 ppm (colour)
Max Printing Resolution Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning 1200 x 1200 dpi
Original Size 216 x 297 mm (max)
Original Type Sheets
Media Size 89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type Envelopes, plain paper, cards, labels, photo paper
Standard Media Capacity 60 sheets
Max Media Capacity 60 sheets
Output Trays Capacity 25 sheets
Connection Availability Yes
Interface USB 2.0, Bluetooth, Wi-Fi(n)
AirPrint Enabled Yes
Office Machine Features HP Instant Ink, print from mobile devices, scan to PDF
Power AC 120/230 V (50/60Hz)
Dimensions (WxDxH) 42.5 cm x 30.4 cm x 15.4 cm
Weight 3.42 kg
Enclosure Colour White
Manufacturer Warranty 1-year warranty
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Damaged stock - Item is new but has packaging damage
Ref: GSQC 047046
£43.46
product
Ref: GSQC 047046
Accessories
Packaging
Functional
Software
Manuals
£43.46
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£49.99
