We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
All the basics, now with easy-to-use features. Print, scan, copy, simple setup with HP Smart app and worry-free wireless. Choose HP+ and get the smart printing system that keeps you connected and ready to print from virtually anywhere.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Product Description | HP Deskjet 2721e All-in-One - multifunction printer - colour - HP Instant Ink eligible | Device Type | Multifunction printer | Localisation | United Kingdom, Ireland | Printing Technology | Ink-jet (colour) | Inkjet Technology | HP Thermal Inkjet - 4-ink | Monthly Duty Cycle (max) | 1000 pages | Recommended Monthly Volume | 50 - 100 pages | Max Copying Speed | Up to 6 ppm (mono) / up to 3 ppm (colour) | Max Printing Speed | Up to 7.5 ppm (mono) / up to 5.5 ppm (colour) | Max Printing Resolution | Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Scanning | 1200 x 1200 dpi | Original Size | 216 x 297 mm (max) | Original Type | Sheets | Media Size | 89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Envelopes, plain paper, cards, labels, photo paper | Standard Media Capacity | 60 sheets | Max Media Capacity | 60 sheets | Output Trays Capacity | 25 sheets | Connection Availability | Yes | Interface | USB 2.0, Bluetooth, Wi-Fi(n) | AirPrint Enabled | Yes | Office Machine Features | Print from mobile devices, scan to PDF | Power | AC 230 V (50/60Hz) | Dimensions (WxDxH) | 42.5 cm x 30.4 cm x 15.4 cm | Weight | 3.42 kg | Enclosure Colour | Indigo | Manufacturer Warranty | 2-year warranty |
General | |
Printing Technology | Ink-jet - colour |
Display Features | Icon LCD display |
Copying | |
Maximum Copies | 9 |
Printing | |
Inkjet Technology | HP Thermal Inkjet |
Nozzle Configuration | 328 nozzles (black), 588 nozzles (colour) |
Ink Cartridge Configuration | 1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, pigment black |
Colour | 4-ink |
Printer Drivers / Emulations | PCL 3 GUI, PCLm, URF |
First Print Out Time B/W | 15 sec |
First Print Out Time Colour | 19 sec |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 1200 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Document & Media Handling | |
Max Original Size | 216 x 297 mm |
Min Media Size | 89 x 127 mm |
Max Media Size | A4/Legal |
Min Media Weight | 60 g/m² |
Max Media Weight | 300 g/m² |
Supported Media Type | Envelopes, plain paper, cards, labels, photo paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 89 x 127 mm |
Supported Envelope Sizes | US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm) |
Document & Media Handling Details | Input tray - 60 sheets size: 89 x 127 mm - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m² , Output tray - 25 sheets |
Speed Details | Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 16 ppm (A4) - colour draft , Printing: up to 7.5 ppm - B/W (ISO) , Printing: up to 5.5 ppm - colour (ISO) , Copying: up to 6 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO) |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B |
Operating System Support | MS Windows 7 (32/64 bits), Windows 10 (32/64-bits), macOS 10.13, macOS 10.14, macOS 10.15 |
Software Included | Drivers & Utilities, HP Smart App |
Power | |
Voltage Required | AC 230 V (50/60Hz) |
Power Consumption Standby | 2.5 Watt |
Power Consumption Sleep | 1.1 Watt |
Miscellaneous | |
Compliant Standards | FCC CFR47 Part 15 B, EN 62479:2010, EN 61000-3-3:2013, CISPR 24:2010, IEC 61000-3-3:2013, EN 55024:2010, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55032:2015, ICES-003 issue 6 Class B, EN 301 489-17 V3.1.1 (2017), CISPR 32:2015 Class B, EN 301 489-1 V2.1.1:2017, EN 55035:2017, EN 62368-1:2014+A11:2017, IEC 61000-3-2:2014, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, EN 300 328 V2.1.1:2016, CISPR 35: 2016, EN 301 893 V2.2.1:2017 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight | |
Width | 42.5 cm |
Depth | 30.4 cm |
Height | 15.4 cm |
Weight | 3.42 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 47.5 cm |
Shipping Depth | 19.1 cm |
Shipping Height | 35.4 cm |
Shipping Weight | 4.58 kg |
Environmental Parameters | |
Sound Emission | 48 dBA (operating) |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
