All the features. All the value. Print, scan, and copy, and get a 35 page auto feeder. Count on simple setup[1] and worry-free wireless.[2] Choose HP+ at setup to receive 9 months of Instant Ink [3] and an extended (up to 2 years) HP warranty.[4]
Added extras so you can do more Work fast and hands-free – the 35 page auto feeder helps you complete scan and copy jobs quickly. Easily print, scan, and copy everyday documents from your smartphone, using HP Smart app.[1] Get better range and faster, more reliable connections using dual-band Wi-Fi® with self-reset.[2] Get connected with Bluetooth® and start printing fast from your smartphone or tablet – easy setup.[3]
Simple setup. Simple printing.
Get started fast with simple setup that guides you through each step, using HP Smart app.[1] Easily handle tasks and get a lot from one device – print, scan, and copy. Get quick and easy printing directly at the control panel. This printer is made from recycled printers and other electronics – more than 20% by weight of plastic.
Never run out of ink with Instant Ink[4]
Never run out of ink.[4] Convenient ink cartridge replacements and smart delivery included. Save up to 70% with Instant Ink.[5] Enroll to get ink, delivery and recycling starting at £0.99 a month. Peace of mind with plan flexibility to change or cancel anytime at no cost.[6] Help us put plastic back into printers with prepaid recycling service included.[7]
With HP+, get HP’s simplest printing solution and more value with exclusive use of Original HP Ink. Opt in to HP+ during printer setup to get 9 months of Instant Ink[10] and an extra year of HP warranty (up to 2 years).[4] A cloud-connected HP+ printer is smarter - it keeps itself up to date and ready to print.[8] Never run out of ink and save up to 70% with Instant Ink. 9 months included with HP+.[3,6,7] Print and scan from the palm of your hand. Enjoy advanced productivity features for 2 years with HP+.[1] HP+ requires an HP account, ongoing internet connection, and use of Original HP ink cartridges.
Product Description | HP Deskjet 4130e All-in-One - multifunction printer - colour - HP Instant Ink eligible | Device Type | Multifunction printer | Localisation | United Kingdom, Ireland | Printing Technology | Ink-jet (colour) | Inkjet Technology | HP Thermal Inkjet - 4-ink | Monthly Duty Cycle (max) | 1000 pages | Recommended Monthly Volume | 100 - 300 pages | Max Copying Speed | Up to 6 ppm (mono) / up to 3 ppm (colour) | Max Copying Resolution | Up to 300 x 300 dpi (mono) / up to 300 x 300 dpi (colour) | Max Printing Speed | Up to 8.5 ppm (mono) / up to 5.5 ppm (colour) | Max Printing Resolution | Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Max Fax Transmission Speed | 14.4 Kbps | Scanning | 1200 x 1200 dpi | Original Size | 216 x 297 mm (max) | Original Type | Sheets | Document Feeder Capacity | 35 sheets | Media Size | Legal (216 x 356 mm), A4 (210 x 297 mm) (max) | Media Type | Envelopes, plain paper, cards, labels, photo paper | Standard Media Capacity | 60 sheets | Max Media Capacity | 60 sheets | Output Trays Capacity | 25 sheets | Connection Availability | Yes | Interface | USB 2.0, Wi-Fi(n), Bluetooth 4.2 | AirPrint Enabled | Yes | Office Machine Features | Print from mobile devices, scan to PDF, HP+ enabled | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 42.8 cm x 33.2 cm x 20 cm | Weight | 4.82 kg | Enclosure Colour | Indigo | Environmental Standards | EPEAT Silver | Manufacturer Warranty | 1-year warranty |
General | |
Printing Technology | Ink-jet - colour |
Display Features | LCD display |
Memory | |
Standard Memory | 84 MB |
Max Supported Memory | 84 MB |
Copying | |
Maximum Copies | 9 |
Printing | |
Inkjet Technology | HP Thermal Inkjet |
Nozzle Configuration | 328 nozzles (black), 588 nozzles (colour) |
Ink Cartridge Configuration | 1 pigment black cartridge, 1 colour cartridge (cyan, magenta, yellow) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, pigment black |
Colour | 4-ink |
Printer Drivers / Emulations | PCL 3 GUI, PCLm, URF |
First Print Out Time B/W | 15 sec |
First Print Out Time Colour | 19 sec |
Scanning | |
Scan Element | CIS |
Optical Resolution | 1200 x 1200 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Fax Machine | |
Max Transmission Speed | 14.4 Kbps |
PC Faxing | Yes |
Fax Machine Features | |
Features | Fax forwarding, automatic redialing, Distinctive Ring Detection (DRD), fax polling |
Document & Media Handling | |
Max Original Size | 216 x 297 mm |
Supported Original Sizes | 216 x 297 mm |
Max Media Size | A4/Legal |
Min Media Weight | 60 g/m² |
Max Media Weight | 300 g/m² |
Min Media Weight (lb) | 16 lbs |
Max Media Weight (lb) | 145 lbs |
Supported Media Type | Envelopes, plain paper, cards, labels, photo paper |
Supported Media Sizes | ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 101.6 x 152.4 mm, 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm |
Supported Envelope Sizes | International DL (110 x 220 mm) |
Document & Media Handling Details | ADF - 35 sheets , Input tray - 60 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m²; weight (lbs): 16 lbs - 145 lbs , Output tray - 25 sheets |
Speed Details | Printing: up to 20 ppm (A4) - B/W draft , Printing: up to 16 ppm (A4) - colour draft , Printing: up to 8.5 ppm (A4) - B/W (ISO) , Printing: up to 5.5 ppm (A4) - colour (ISO) , Copying: up to 6 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO) , Scanning: up to 2.5 ppm (A4) - B/W (200 dpi) , Scanning: up to 2.5 ppm (A4) - colour (200 dpi) , Scanning: up to 2.5 ppm (Letter A) - B/W (200 dpi) , Scanning: up to 2.5 ppm (Letter A) - colour (200 dpi) |
Connections | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type B |
Software Included | Drivers & Utilities, HP Smart App |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Power Consumption Sleep | 1.1 Watt |
Miscellaneous | |
Consumables Included | 1 x ink cartridge (black) - HP 67 , 1 x ink cartridge (yellow/cyan/magenta) - HP 67 |
Compliant Standards | FCC Class B certified, FCC CFR47 Part 15, EN 62479:2010, EN 61000-3-3:2013, CISPR 24:2010, IEC 61000-3-3:2013, EN 55024:2010, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55032:2015, ICES-003 issue 6 Class B, EN 301 489-17 V3.1.1 (2017), CISPR 35, CISPR 32:2015 Class B, EN 301 489-1 V2.1.1:2017, EN 55035:2017, EN 62368-1:2014+A11:2017, IEC 61000-3-2:2014, IEC 62368-1: 2014, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 |
Environmental Standards | |
EPEAT Compliant | EPEAT Silver |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight | |
Width | 42.8 cm |
Depth | 33.2 cm |
Height | 20 cm |
Weight | 4.82 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 47.5 cm |
Shipping Depth | 24.2 cm |
Shipping Height | 40.5 cm |
Shipping Weight | 6.19 kg |
Environmental Parameters | |
Sound Emission | 56 dBA (operating) |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 15 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
