HP Desktop Mini Lockbox
Key features
  • After you’ve installed and mounted your system inside the HP Desktop Mini LockBox, add a traditional padlock or an HP UltraSlim Lock for an extra layer of protection.
  • Help deter pulling, tugging or disconnecting cables from the outside with integrated cable routing and clips. Simply remove the protection plate when you need access to front ports and the power button.
  • Place your PC, power brick, and cable connections inside the enclosure and use the VESA pattern to mount to a flat surface, like a wall or a desk.
  • Take your PC security to the max with a durable metal enclosure that’s specifically engineered to protect your HP Desktop Mini PC.
Product codes
Fortify your HP Desktop Mini in a range of settings with the HP Desktop Mini LockBox, HP's most secure enclosure for your PC, power brick, and cable connections.
Compatible with the HP ProDesk 400 G2 DM (Mini); HP EliteDesk 800 G2 35W, 800 G2 65W, HP Collaboration PC G2.
HP Desktop Mini LockBox - PC enclosure system
PC enclosure system
Placing / Mounting
Wall mountable, under-desk mountable
Package Content
Mounting screws
Jack black
Product Material
Metal, mesh
27.2 cm x 5.72 cm x 26.8 cm
2.391 kg
Padlock loop, VESA 100 x 100 mm, VESA 75 x 75 mm
EliteDesk 705 G3 (mini desktop); ProDesk 400 G3 (mini desktop), 600 G2
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
