HP Dreamcolor Z27x 27" 2560x1440 12ms VGA DVI-D DisplayP...
HP Dreamcolor Z27x 27" 2560x1440 12ms VGA DVI-D DisplayPort with HDCP USB IPS LED Monitor
Key features
  • Deliver rich, accurate colors and ultra-deep blacks with HP’s 68.6 cm (27") diagonal DreamColor panel.
  • Easily create your own color space with the integrated calibration engine.
  • Power through your 4K content with 10-bit accuracy with the HP DreamColor Engine 2.
Product codes
Work in brilliant, trusted color and bring your ideas to life with the HP DreamColor Z27x Studio Display, featuring HP's unrivaled integrated calibration engine, 4K input support, and 10-bit color that drives up to 1.07 billion onscreen colors.
Product Description HP DreamColor Z27x Professional - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class C
Energy Consumption per Year 86 kWh
Power Consumption (On mode) 59 W
Features USB Hub
Panel Type AH-IPS
Aspect Ratio 16:9
Native Resolution 2560 x 1440 at 60 Hz
Pixel Pitch 0.2331 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 12 ms
Colour Support 1.07 billion colours
Input Connectors HDMI, 2xDisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 64.1 cm x 24.24 cm x 42.04 cm
Weight 8.8 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CEL, EPA, TCO Displays, ISC, CEL Grade 2
Manufacturer Warranty 5 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Dreamcolor Z27x 27"...
