HP DreamColour Z24 G2 24" 1920x1200 6ms HDMI DVI-D Displ...
HP DreamColour Z24 G2 24" 1920x1200 6ms HDMI DVI-D DisplayPort LED Monitor
£642.60
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Achieve minimal banding across your project’s color gradients with a bit depth of 10 bits that produces 1,024 gray levels per channel and up to a billion colors.
  • Experience color accuracy between each of your HP DreamColor displays when you calibrate any of the four color space presets or create your own with HP DreamColor Calibration Software.
  • Get a wide array of digital cinema-class color gamuts, including 100% coverage of sRGB and BT.709 and 99% of Adobe® RGB, and great on-and off-axis views from the wide-angle HP DreamColor panel.
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1200
  • Response Time: 6ms
  • Interfaces: DisplayPort, DVI, HDMI
  • Stock Status: In Stock
Product codes
Enjoy pure, consistent color accuracy from design to production with push-button color space selection and easy color calibration on the amazingly affordable 61 cm (24") diagonal HP DreamColor Z24x G2 Display.
Product Description HP DreamColor Z24x G2 - LED monitor - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class B
Energy Consumption per Year 43 kWh
Power Consumption (On mode) 29 W
Features USB 3.0 hub
Panel Type AH-IPS
Aspect Ratio 16:10
Native Resolution WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch 0.27 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 6 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors HDMI, DVI-D, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) 55.94 cm x 23.8 cm x 52.5 cm
Weight 6.98 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, low halogen
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP DreamColour Z24 G2...
£642.60
