We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Boost your creativity with the HP DreamColor Z27x G2 Studio Display. Designed for color professionals, this 27" diagonal Quad HD display has breakthrough HP DreamColor Technology, an expansive color gamut, built-in colorimeter, and workflow management tools.
Product Description | HP DreamColor Z27x G2 Studio Display - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class G | Energy Consumption per Year | 64 kWh | Power Consumption (On mode) | 44 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 at 60 Hz | Pixel Pitch | 0.2331 mm | Brightness | 250 cd/m² | Contrast Ratio | 1500:1 | Response Time | 10.2 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Colour Gamut | 100% BT.709, 100% sRGB, 98% DCI-P3, 99% Adobe RGB | Input Connectors | 2xHDMI, 2xDisplayPort, USB-C | Built-in Ethernet | Yes | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 64.21 cm x 24.8 cm x 57.28 cm | Weight | 12.1 kg | Localisation | English / United Kingdom | Compliant Standards | Plug and Play, CSA, TUV GS, VCCI, BSMI, WHQL, CB, CCC, TUV Ergo, FCC, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, E-Standby, KC, EPA, CEL Grade 3 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Pixel Per Inch | 109 |
Vertical Refresh Rate | 24 - 60 Hz |
Horizontal Refresh Rate | 27 - 90 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 6504K |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | Picture by picture, HDCP, Low Blue Light Mode, Flicker Free technology, Mercury free, Factory Calibration, arsenic-free glass, Zero Bright Dot Warranty, Picture-in-Picture |
Colour | Black |
Dimensions (WxDxH) | 64.21 cm x 24.8 cm x 57.28 cm - with stand |
Weight | 12.1 kg |
Connectivity | |
Interfaces | 2 x HDMI (HDCP) , 2 x DisplayPort (HDCP) , USB-C 3.1 Gen 1 upstream/DisplayPort Alt Mode with Power Delivery (HDCP) , USB (Type A) , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 3.0 downstream (fast charging) , Audio line-out , Management (RJ-45) |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 90 |
Height Adjustment | 201 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand |
Cables Included | 1 x USB-C cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB-C to USB-A cable - 1.8 m , 1 x USB-B to USB-A cable - 1.8 m |
Backlight Life | 30,000 hour(s) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 32.1 kWh/1000h |
Power Consumption (Typical) | 65 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities |
OS Required | Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 64.21 cm - depth: 8.25 cm - height: 38.21 cm - weight: 7.4 kg , With stand - width: 64.21 cm - depth: 24.8 cm - height: 57.28 cm - weight: 12.1 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 78.4 cm |
Shipping Depth | 38 cm |
Shipping Height | 49.4 cm |
Shipping Weight | 16 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
