HP DreamColour Z27x G2 27" 2560x1440 10.2ms 2xHDMI 2xDis...
HP DreamColour Z27x G2 27" 2560x1440 10.2ms 2xHDMI 2xDisplayPort USB-C LED Monitor
£1,874.79
32 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Achieve accurate color with a pop-up sensor that calibrates on demand or on a regular schedule. Free up valuable time for other tasks and no longer wonder if your color is correct.
  • Experience precise, rich color with HP DreamColor Technology. Our extensive color spectrum offers over one billion colors with DCI P3 coverage for exceptionally smooth transitions.
  • HP worked with leading visual effects studios to create customized solutions for an optimal design process, including onscreen markers and keyboard-based input switching between your devices.
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 10.2ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, USB-C
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £1,878.28
Save £1.50
Boost your creativity with the HP DreamColor Z27x G2 Studio Display. Designed for color professionals, this 27" diagonal Quad HD display has breakthrough HP DreamColor Technology, an expansive color gamut, built-in colorimeter, and workflow management tools.
Product Description HP DreamColor Z27x G2 Studio Display - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class C
Energy Consumption per Year 64 kWh
Power Consumption (On mode) 44 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 60 Hz
Pixel Pitch 0.2331 mm
Brightness 250 cd/m²
Contrast Ratio 1500:1
Response Time 10.2 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors 2xHDMI, 2xDisplayPort, USB-C
Display Position Adjustments Height, swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 64.21 cm x 24.8 cm x 57.28 cm
Weight 12.1 kg
Localisation English / United Kingdom
Compliant Standards Plug and Play, CSA, TUV GS, VCCI, BSMI, WHQL, CB, CCC, TUV Ergo, FCC, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, E-Standby, KC, EPA, CEL Grade 3
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP DreamColour Z27x G2...
£1,874.79
