HP Dual Hinge II Notebook Stand for 2013 Slim Dock
£139.68
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • If you prefer to work without a dock, you can park the notebook in the tray on its own. Use the cable routing feature to keep cables out of the way and create a clean working area.
  • Simply snap the docking station into the tray, attach your peripherals, and you’re ready to work every time you dock your notebook.
  • Use the stand with a range of HP notebooks and docking stations. Dependent on your docking station’s ports, you can also connect peripherals such as a keyboard and mouse or external drive for a total workspace solution.
  • Device Type: Laptop
  • Stock Status: In Stock
Product codes
Quickly and easily create a comfortable workspace for your notebook or notebook and docking station by bringing them up off the desk in the HP Dual Hinge II Notebook Stand.
Product Description HP Dual Hinge II Notebook Stand notebook stand
Product Type Notebook stand
Dimensions (WxDxH) 30 cm x 36 cm x 22 cm
Weight 3.6 kg
Features Double hinged, tilt adjustment, adjustable height
Designed For HP 470 G7; Chromebook 11 G8, 11A G8, 14 G6; Chromebook Enterprise 14 G6; Chromebook Enterprise x360; Chromebook x360; EliteBook 830 G7, 845 G7, 85X G7; EliteBook x360; Pro c640; ProBook 430 G7, 440 G8, 44X G7, 45X G7, 630 G8, 635, 640 G8; ProBook x360; ZBook Firefly 15 G7; ZBook Fury 15 G7, 17 G7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Dual Hinge II Noteb...
£139.68
