HP E22 G4 21.5" 1920x1080 5ms VGA USB HDMI Full HD IPS M...
FREE DELIVERY
HP E22 G4 21.5" 1920x1080 5ms VGA USB HDMI Full HD IPS Monitor
£227.37
Delivery:
Notify me
Key features
  • Energy efficiency is built into every ENERGY STAR certified, EPEAT 2020 registered, and low halogen display. We go one step further with 100% recyclable packaging.
  • Keep your eyes comfortable through the work day with HP Eye Ease, our first built-in, always-on blue light filter that has zero impact on your color accuracy and works without an OSD.
  • Never lose a moment of productivity with 4-way monitor adjustability, a 3-sided micro-edge, flicker-free 54.61 cm (21.5-inch) diagonal screen, and Full HD resolution.
  • Diagonal Size: 22in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Interfaces: DisplayPort, VGA (HD-15), HDMI
Product codes
Work comfortably and stay focused with the optimized ergonomics and Full HD resolution of the HP E22 G4 FHD Monitor with HP Eye Ease that is designed around you. Make life easy for IT with remote manageability.
Product Description HP E22 G4 - E-Series - LED monitor - Full HD (1080p) - 22"
Device Type LED-backlit LCD monitor - 22"
Energy Class Class D
Energy Consumption per Year 16 kWh
Power Consumption (On mode) 13 W
Features USB 3.2 Gen 1 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.24795 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Gamut 72% NTSC
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare 3H hardness
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) - with stand 48.87 cm x 20.7 cm x 48.06 cm
Weight 5.3 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
Compliant Standards Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, KC, CEL, EAC, CEL Grade 1, ISC, low halogen, DisplayPort 1.2, ICE, HP GSE, Australian-New Zealand MEPS, Vietnam MEPS
Bundled Services HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£227.37
Notify me
