Work comfortably and stay focused with the optimized ergonomics and Full HD resolution of the HP E23 G4 FHD Monitor with HP Eye Ease that is designed around you. Make life easy for IT with remote manageability.
Product Description | HP E23 G4 - E-Series - LED monitor - Full HD (1080p) - 23" | Device Type | LED-backlit LCD monitor - 23" | Energy Class | Class E | Energy Consumption per Year | 24 kWh | Power Consumption (On mode) | 16 W | Features | USB 3.2 Gen 1 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.265 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey with overdrive) | Colour Gamut | 72% NTSC | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black, silver | Dimensions (WxDxH) - with stand | 52.16 cm x 20.7 cm x 48.98 cm | Weight | 5.4 kg | Localisation | English / United Kingdom | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified | Compliant Standards | Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, MEPS, KC, CECP, CEL, EAC, CEL Grade 1, ISC, SEPA, BIS, low halogen, DisplayPort 1.2, ICE, UAE, HDCP | Manufacturer Warranty | 3-year warranty | Bundled Services | HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23" |
Built-in Devices | USB 3.2 Gen 1 hub |
Panel Type | IPS |
Pixel Per Inch | 96 |
Vertical Refresh Rate | 50 - 60 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 6500K |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic free, 3-sided micro-edge, 6-bit + FRC Color Depth, edge-lit LED backlight, 72% NTSC colour gamut |
Dimensions (WxDxH) | 52.16 cm x 20.7 cm x 48.98 cm - with stand |
Weight | 5.4 kg |
Connectivity | |
Interfaces | DisplayPort 1.2 , HDMI , VGA , 4 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 upstream (Type B) |
Mechanical | |
Tilt Angle | -5/+23 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand, VESA interface support |
Cables Included | 1 x DisplayPort 1.2 cable - 1.8 m , 1 x USB-B to USB-A cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x VGA cable |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 16 kWh/1000h |
Power Consumption (Typical) | 26 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | HP Display Center |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 52.16 cm - depth: 20.7 cm - height: 48.98 cm - weight: 5.4 kg , Without stand - width: 52.16 cm - depth: 4.7 cm - height: 31.31 cm - weight: 3.12 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 58.1 cm |
Shipping Depth | 22.3 cm |
Shipping Height | 37.2 cm |
Shipping Weight | 8 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
ENERGY STAR Certified | Yes |
ENERGY STAR Version | 8.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
