We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Work comfortably and stay focused with the optimized ergonomics and Full HD resolution of the HP E27 G4 FHD Monitor with HP Eye Ease that is designed around you. Make life easy for IT with remote manageability.
Product Description | HP E27 G4 - E-Series - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class D | Power Consumption (On mode) | 16.9 W | Features | USB 3.2 Gen 1 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.311 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey with overdrive) | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare 3H hardness | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 61.17 cm x 21.6 cm x 53.52 cm | Weight | 6.9 kg | Localisation | English / United Kingdom | Pricing Type | Promo | Environmental Standards | TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified | Compliant Standards | TUV, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, CEC, KC, CECP, CEL, EAC, ISC, SEPA, BIS, low halogen, ICE, TUV LBL, Australian-New Zealand MEPS, Vietnam MEPS, TGM | Bundled Services | HP 5 years Next Business Day Onsite Hardware Support for Standard Monitors |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | USB 3.2 Gen 1 hub |
Panel Type | IPS |
Pixel Per Inch | 82 |
Vertical Refresh Rate | 50 - 60 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, 6-bit + FRC Color Depth, HP Eye Ease |
Colour | Black |
Dimensions (WxDxH) | 61.17 cm x 21.6 cm x 53.52 cm - with stand |
Weight | 6.9 kg |
Connectivity | |
Interfaces | DisplayPort 1.2 , HDMI , VGA , 4 x USB 3.2 Gen 1 downstream , USB (Type B) |
Mechanical | |
Tilt Angle | -5/+23 |
Swivel Angle | 90 |
Rotation Angle | 180 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand, VESA interface support |
Cables Included | 1 x HDMI cable , 1 x DisplayPort 1.2 cable , 1 x USB-B to USB-A cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 16.9 kWh/1000h |
Power Consumption (Typical) | 22 Watt |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.17 cm - depth: 21.6 cm - height: 53.52 cm - weight: 6.9 kg , Without stand - width: 61.17 cm - depth: 4.7 cm - height: 36.36 cm |
Dimensions & Weight (Shipping) | |
Shipping Width | 69.5 cm |
Shipping Depth | 44.4 cm |
Shipping Height | 22.5 cm |
Shipping Weight | 10.4 kg |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8, TCO Certified Edge Displays |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
