We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Inspire joy on your desk with the clean connectivity of the HP E27d G4 QHD Advanced Docking Monitor. Add your everyday accessories at the display, then add your PC with just one USB-C cable. Empower IT to remotely manage HP devices from anywhere on the network through RJ-45.
Product Description | HP E27d G4 Advanced Docking Monitor - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class F | Energy Consumption per Year | 43 kWh | Power Consumption (On mode) | 25.7 W | Features | 2 microphones, IR camera, USB 3.0/USB-C hub, USB PD 100 Watt | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 at 60 Hz | Pixel Pitch | 0.2331 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 5 ms | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 100 - 240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 61.36 cm x 4.85 cm x 53.54 cm | Weight | 8.2 kg | Localisation | English / United Kingdom | Compliant Standards | Plug and Play, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, MEPS, E-Standby, CEC, KC, CECP, EAC, CEL Grade 1, ISC, BIS, DisplayPort 1.2, DisplayPort 1.4, SmartWay, HP GSE, AUS/NZ | Manufacturer Warranty | 3-year warranty | Bundled Services | HP 5 years Next Business Day Bundled Support Extension for Monitors (United Kingdom) |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Built-in Devices | 2 microphones, IR camera, USB 3.0/USB-C hub |
USB Power Delivery | 100 Watt |
Panel Type | IPS |
Pixel Per Inch | 109 |
Vertical Refresh Rate | 48 - 75 Hz |
Horizontal Refresh Rate | 30 - 90 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 6500K |
OSD Languages | Chinese (traditional), Chinese (simplified), English, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | HDCP, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, Windows 10 Hello, 8-bit Colour Depth, 99% sRGB colour gamut |
Colour | Black |
Dimensions (WxDxH) | 61.36 cm x 4.85 cm x 53.54 cm - with stand |
Weight | 8.2 kg |
Connectivity | |
Interfaces | DisplayPort (HDCP) , DisplayPort output , HDMI (HDCP) , USB-C 3.1 Gen 1 upstream/DisplayPort Alt Mode with Power Delivery (power up to 100W) , USB-C downstream , 4 x USB 3.0 downstream , Headphone/microphone combo jack (mini-jack) |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 60 |
Rotation Angle | 180 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand, arsenic free, mercury free |
Cables Included | 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x USB 3.1 Gen 2 cable - 1 m |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100 - 240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 25.7 kWh/1000h |
Power Consumption (Typical) | 80 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | HP Display Assistant |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.36 cm - depth: 4.85 cm - height: 53.54 cm - weight: 8.2 kg , Without stand - width: 61.36 cm - depth: 4.85 cm - height: 36.6 cm - weight: 5.5 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 69.6 cm |
Shipping Depth | 27.5 cm |
Shipping Height | 46.9 cm |
Shipping Weight | 13.3 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
