General |
Product Type |
Tablet - with detachable keyboard |
Operating System |
Windows 10 Pro 64-bit Edition - English |
Processor / Chipset |
CPU |
Intel Core i3 (8th Gen) 8130U / 2.2 GHz |
Max Turbo Speed |
3.4 GHz |
Number of Cores |
Dual-Core |
Cache |
4 MB |
64-bit Computing |
Yes |
Features |
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory |
RAM |
4 GB (provided memory is soldered) |
Max RAM Supported |
16 GB |
Technology |
LPDDR3 SDRAM |
Speed |
2133 MHz |
Rated Speed |
2133 MHz |
Storage |
Main Storage |
128 GB SSD - (M.2 2280) PCIe |
Display |
Type |
13" - IPS |
LCD Backlight Technology |
LED backlight |
Touchscreen |
Yes (multi-touch) |
Resolution |
3000 x 2000 (3K2K) |
Widescreen |
Yes |
Image Aspect Ratio |
3:2 |
Image Brightness |
450 cd/m² |
Features |
100% sRGB colour gamut, Corning Gorilla glass 4, Low Power Ultra Slim bent |
Keyboard Name |
HP Premium Collaboration Keyboard |
Audio & Video |
Graphics Processor |
Intel UHD Graphics 620 |
Memory Allocation Technology |
Shared Video Memory (UMA) |
Camera |
Yes - VGA |
Camera Features |
IR camera, Windows Hello |
Sound |
Stereo speakers, 3 multi-array microphone |
Audio Features |
Noise-cancellation technology, Bang & Olufsen Audio |
Input |
Type |
Keyboard, ClickPad |
Keyboard Layout |
UK |
Features |
Volume control, touchpad with gesture support, gesture function |
Communications |
Wireless |
802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller |
Intel Dual Band Wireless-AC 8265 |
Features |
Intel Wireless Display (WiDi), dual stream (2x2) |
Compliant Standards |
IEEE 802.11i, Wi-Fi CERTIFIED |
Battery |
Technology |
4-cell lithium polymer |
Installed Qty |
1 |
Capacity |
50 Wh |
Run Time |
Up to 10.5 hours |
AC Adapter |
Input |
AC 120/230 V (50/60 Hz) |
Output |
65 Watt |
Connections & Expansion |
Interfaces |
2 x USB-C 3.1/Thunderbolt , USB-C 3.1/DisplayPort (Power Delivery) , Headphone/microphone combo jack |
Memory Card Reader |
Yes (microSD, microSDHC, microSDXC) |
Software |
Software Included |
HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Systems Software Manager (free download), HP Velocity, HP BIOS Configuration Utility (free download), HP Client Catalog, HP JumpStart, HP Workwise, HP Noise Cancellation, HP JetAdvantage, HP PhoneWise, HP Manageability & Integration Kit Gen2, Ivanti Management Suite |
Miscellaneous |
Integrated Options |
Accelerometer, ambient light sensor, proximity sensor, magnetometer, gyro sensor, hall sensor |
Security |
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader |
Features |
HP Automatic Drive Lock, HP DriveLock, HP Fingerprint Sensor, Secure Erase, HP Sure Start Gen 4, HP Sure Run, HP Sure Recover, HP Wireless Wakeup, HP Sure Click |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately) |
Security Slot Type |
Kensington nano security slot |
Included Accessories |
Keyboard, USB-C power adapter, WACOM AES pen |
Low halogen |
Localization |
Language: English / region: United Kingdom |
Dimensions & Weight |
Dimensions (WxDxH) - tablet |
30 cm x 23.15 cm x 0.79 cm |
Weight |
820 g |
Dimensions (WxDxH) / Weight Details |
30 cm x 23.15 cm x 1.33 cm / 1.17 kg - tablet with keyboard , 30 cm x 23.15 cm x 0.79 cm / 820 g - tablet |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Environmental Parameters |
Min Operating Temperature |
0 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
10 - 90% (non-condensing) |
Shock Tolerance (operating) |
40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) |
240 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) |
1.043 g @ RMS (random) |
Vibration Tolerance (non-operating) |
3.5 g @ RMS (random) |
