HP EliteBook 725 G2 - A series A8 PRO-7150B / 1.9 GHz - Win
Key features
  • Enjoy the intuitive control and impressive clarity of the optional FHD touchscreen featuring tough Corning® Gorilla® Glass 3 that lets you make the most of Windows 8.1.
  • HP Sure Start is the way to help ensure a proper boot-up thanks to corruption detection, a self-healing BIOS, and recovery that restarts where it left off if the update stalls, fails, or is corrupted.
  • Never fear bumps and minor spills. The thin and light HP EliteBook 725 G2 endures HP’s Total Test Process and is designed to undergo MIL-SPEC 810G testing.
  • The HP EliteBook 725 G2 delivers future-ready performance at an exceptional price. Featuring AMD PRO A-Series APUs now with revolutionary HSA technology, a lightweight design, and an optional FHD touch display that allows you to navigate easily and get work done.
  • The latest AMD A-Series Pro APUs with HSA technology help unlock true business computing and deliver outstanding total cost of ownership, optimal manageability, and security features. Simply put, AMD A-Series PRO APUs are easy to support with the power to perform.
Product codes
The thin and light design with optional FHD touch display makes the HP EliteBook 700 series ideal for professionals in and out of the office. Work proficiently and confidently with HP technology and AMD PRO A-Series APUs.
At your fingertips.
Field ready.
Self-healing safeguard.
Featuring
Product Description HP EliteBook 725 G2 - 12.5" - A8 PRO-7150B - 4 GB RAM - 128 GB SSD - UK
Product Type Notebook
Operating System Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor AMD A8 PRO-7150B / 1.9 GHz (3.2 GHz) / 4 MB Cache
Memory 4 GB DDR3L (1 x 4 GB)
Storage 128 GB SSD
Optical Drive No optical drive
Display 12.5" LED backlight 1366 x 768 / HD
Graphics AMD Radeon R5
Input Device Pointing stick
Keyboard UK
Keyboard Backlight Yes
Integrated Webcam Yes
Networking 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
Battery 3-cell - up to 7.75 hours
Dockable Yes
Security Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Dimensions (WxDxH) 31.1 cm x 21.53 cm x 2.1 cm
Weight 1.45 kg
Localisation Language: English / region: United Kingdom
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - parts and labour - 3 years - on-site
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteBook 725 G2 -...
