HP EliteBook 725 G4 A10-8730B 4GB 500GB 12.5" Windows 10...
£1,016.80
Delivery:
Key features
  • Calls and media are loud and clear with premium speakers, Audio by Bang & Olufsen, HP Audio Boost, and HP Noise Cancellation.
  • Protect and manage your HP EliteBook 725 using HP Sure Start with Runtime Intrusion Detection, HP Touchpoint Manager, and DASH manageability.
  • Stay connected with plenty of ports on the 18.9mm ultrathin HP EliteBook 725.
  • Unleash the full potential of your applications with 6th generation or 7th generation AMD PRO APUs with up to Radeonâ„¢ R7 integrated graphics.
  • Display Size: 12.5in
  • Processor Model: A10 PRO-8730B, A10 PRO-8730B
  • Operating System: Windows 10 Pro 64-bit Edition
  • Installed Memory: 4GB, 4GB
  • Hard Drive Capacity: 500GB
Product codes
Designed for the modern workforce, the cost-effective ultrathin HP EliteBook 725 helps drive performance with impressive productivity features that allow you to stay connected and collaborate at your best.
Elevated performance. Enhanced productivity.
Unleash the full potential of your applications with 6th generation or new high-performance 7th generation AMD PRO APUs with up to Radeonâ„¢ R7 integrated graphics.
Incredibly thin and impressively featured
Stay portable without having to carry adapters. Connect via VGA, Display Portâ„¢, Ethernet, USB, USB-Câ„¢, and enterprise docking capabilities, all on an 18.9mm ultrathin and light design.
Security and management made simple
HP Sure Start with Runtime Intrusion Detection protects the PC and helps ensure uninterrupted productivity by automatically detecting and recovering from BIOS corruption or attacks. Manage the fleet with HP Touchpoint Manager and DASH manageability.
Next-level collaboration
Calls and media are loud and clear letting you collaborate effectively with expertly tuned Audio by Bang & Olufsen, HP Audio Boost, HP Noise Cancellation, and premium speakers.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, sleek, thin, light, and touch optional HP EliteBook 725.
Self-healing safeguard
HP Sure Start with Runtime Intrusion Detection monitors in-memory BIOS, recovers the platform without user or admin intervention, restores the BIOS to a custom state, and is enterprise ready for centralized management.
Get PC images right the first time
Improve the quality and security of custom Windows images with HP Image Assistant which assists ITDMs with image creation, identifies problems, and provides recommendations and remediation.
Speed up the basics of IT management
The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
Charge faster
Get up to 50% battery life in just 30 minutes of charging with and HP fast charging battery.
Give your speakers a boost
HP Audio Boost balances loudness and clarity, and enhances bass for improved speech quality.
Cut out the chatter
Suppress background noise including keyboard clicks with HP Noise Cancellation Software.
Office intelligence
HP WorkWise is office intelligence rolled into one smartphone app.
Product Description HP EliteBook 725 G4 - 12.5" - A10 PRO-8730B - 4 GB RAM - 500 GB HDD - UK
Product Type Notebook
Operating System Win 10 Pro 64-bit - English
Processor AMD A10 PRO-8730B / 2.4 GHz (3.3 GHz) / 2 MB Cache
Memory 4 GB DDR4 (1 x 4 GB)
Storage 500 GB HDD / 7200 rpm
Optical Drive No optical drive
Display 12.5" LED backlight 1366 x 768 / HD
Graphics AMD Radeon R5
Input Device Pointing stick
Keyboard UK
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
Battery 3-cell - up to 9.75 hours
Dockable Yes
Security Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Dimensions (WxDxH) 31 cm x 21.89 cm x 1.89 cm
Weight 1.26 kg
Localisation Language: English / region: United Kingdom
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteBook 725 G4 A1...
£1,016.80
