HP Elitebook 820 I7-6500U 12 8GB/256
£1,436.66
Delivery:
Key features
  • Be free of dongles and get all the ports you need to connect on the 18.9 mm ultraslim design.
  • Collaborate effectively with others using Audio by Bang & Olufsen and HP Noise Reduction Software.
  • Combine power and speed with Windows 10, 6th Gen Intel® Core™ processors, a PCIe Gen3 SSD, and DDR4 memory.
  • Protect your HP EliteBook 820 using HP Sure Start with Dynamic Protection which monitors and corrects BIOS corruption every 15 minutes.
  • Display Size: 12.5in
  • Processor Model: I7-6500U
  • Operating System: Windows 10 Pro 64-bit Edition
  • Installed Memory: 8GB
  • Hard Drive Capacity: 256GB
Product codes
Impressively thin and light, the HP EliteBook 820 empowers users to create, connect, and collaborate, using enterprise-class performance technology that helps keep you productive in and out of the office.
Portable powerhouse
Combine high performance technology and long battery life with Windows 10 Pro, 6th Gen Intel® Core™ processors, and a PCIe Gen3 SSD. Unlock next generation memory performance with DDR4 memory for your most demanding business applications.
Slim new design with all the right ports
Connect to essential ports you need without the hassle of dongles. At just 18.9 mm, the ultraslim and light HP EliteBook 820 comes with VGA, Display Port, RJ-45, USB, USB-C™, and enterprise docking capabilities.
Strong security, powerful manageability
Protect, detect, and recover from malicious attacks with HP Sure Start with Dynamic Protection - the industry’s first self-healing BIOS that monitors and corrects BIOS corruption every 15 minutes.
Designed for collaboration
Replace your speaker phone with the HP EliteBook 820 with Audio by Bang & Olufsen plus HP Noise Reduction Software that provides a rich collaboration experience for applications like Skype for Business.
Product Description HP EliteBook 820 G3 - 12.5" - Core i7 6500U - 8 GB RAM - 256 GB SSD - QWERTY UK
Product Type Notebook
Operating System Win 10 Pro 64-bit - English
Processor Intel Core i7 (6th Gen) 6500U / 2.5 GHz (3.1 GHz) / 4 MB Cache
Memory 8 GB DDR4 (1 x 8 GB)
Storage 256 GB - M.2 SSD
Optical Drive No optical drive
Display 12.5" LED backlight 1920 x 1080 / Full HD
Graphics Intel HD Graphics 520
Input Device Pointing stick
Keyboard Backlight Yes
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
Battery 3-cell
Dockable Yes
Security Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Dimensions (WxDxH) 31 cm x 21.89 cm x 1.89 cm
Weight 1.26 kg
Localisation Language: English / region: United Kingdom
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP Elitebook 820 I7-65...
£1,436.66
