Elevate your business with an ultrathin, professional laptop that empowers users to perform at their very best. Enterprise-class features, comprehensive security, and a refined collaboration experience handle even the most demanding tasks with streamlined efficiency.
Security inside and out
Get end-to-end protection from HP’s most secure and manageable PCs. The optional HP Sure View integrated privacy screen keeps visual hackers in the dark with the touch of a button while HP Sure Start Gen3 protects against BIOS attacks.
High performance, high portability
Speed up demanding business applications and data. Combine high-performance and long battery life with 7th Gen Intel® Core™ processors, and PCIe Gen3 solid state drives. Amplify performance with up to 32 GB of DDR4 memory and dual storage options.
Thin design, no adapters needed
Give portability a whole new meaning with an ultrathin design that doesn’t cut corners. Starting at an incredible 18.9mm, the HP EliteBook 840 includes several full-size ports like VGA, DisplayPort™, RJ-45, and enterprise docking.
See and hear them clearly
Give your online collaboration the sharpness and clarity of a face-to-face meeting with HP Audio Boost, HP Noise Cancellation software, Audio by Bang & Olufsen, and an optional 720p webcam.
Product Description | HP EliteBook 840 G4 - 14" - Core i5 7200U - 4 GB RAM - 256 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache | Memory | 4 GB DDR4 (1 x 4 GB) | Storage | 256 GB SSD HP Z Turbo Drive | Optical Drive | No optical drive | Display | 14" LED backlight 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 620 | Keyboard | UK | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 3-cell - up to 15.25 hours | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip, smart card reader | Dimensions (WxDxH) | 33.8 cm x 23.7 cm x 1.89 cm | Weight | 1.48 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD PCIe - HP Z Turbo Drive |
Display | |
Type | 14" - TN |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Features | Slim Design, Full HD standard-viewing angle (SVA) eDP anti-glare |
Keyboard Name | HP Premium |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - 720p |
Sound | Stereo speakers, two microphones |
Audio Features | Bang & Olufsen Audio, HP Audio Boost |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Touchpad with gesture support |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 - PCI Express Mini Card (M.2) |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-V |
Remote Management Protocol | SNMP 2 |
Features | Wake-on-LAN (WOL) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 51 Wh |
Run Time | Up to 15.25 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt |
Connections & Expansion | |
Slots | 1 x SIM card (1 free) |
Interfaces | USB 3.1 Gen 1 , USB 3.1 Gen 1 (charging) , USB-C , DisplayPort , VGA , LAN , Dock , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Software | |
Software Included | Skype, LANDesk Management Suite, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Systems Software Manager, Password Manager, HP Client Security, HP Velocity, HP Secure Erase, HP BIOSphere, HP Client Catalog, HP BIOS Config Utility, HP Device Access Manager, HP 3D DriveGuard, HP Mobile Connect Pro, HP Image Assistant, HP JetAdvantage Connect, HP Workwise |
Miscellaneous | |
Dockable | Yes |
Features | BIOS Absolute Persistence, Pre-boot Authentication, HP Sure Start Gen 3 |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.48 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years |
