HP EliteDesk 705 G3 - A series A10 PRO-9700E 3 GHz - 8 GB - 2...
HP EliteDesk 705 G3 - A series A10 PRO-9700E 3 GHz - 8 GB - 256 GB
Key features
  • AMD PRO A-Series APUs with Radeon™ graphics deliver dependable performance for your business.
  • Deploy your HP EliteDesk 705 Desktop Mini using mounting, expansion, and security accessory options for your work space.
  • Take care of your work and optimize your work space with the small, full featured, and powerful HP EliteDesk 705 Desktop Mini.
  • Your security safeguard to manage critical business data and devices.
Product codes
Get uncompromising performance from the space-saving HP EliteDesk 705 Desktop Mini with powerful security, manageability, and a unique portfolio of accessories to support your enterprise.
Discover the value of the Desktop Mini
Take care of your work and optimize your work space. Get up to 32 GB of DDR4 memory, fast SSD drives, and add useful accessories for the small, full featured and powerful HP EliteDesk 705 Desktop Mini without breaking the budget.
Security built in
IT efficiency reigns supreme when it’s backed by comprehensive security solutions, including HP BIOSphere with HP Sure Start Gen , AMD Secure Processor, and TPM 2.0.
Bring big power to tight spaces
Utilize innovative mounting, expansion, and security accessory options to create the right solution for your workspace. Incorporate an Elite display for the optimal zero footprint solution.
Pure performance and enhanced visual experience
The latest AMD PRO A-Series APUs with Radeon™ graphics deliver desktop performance optimized for diverse digital workloads and dependable daily productivity across your business.
Let nothing stand in your way
Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today’s security threats and maximize management and productivity features for business.
Ready to go the distance
The HP EliteDesk 705 Desktop Mini endured 120,000 hours of the HP Total Test Process and is designed to pass MIL-STD 810G testing. This combined with HP temperature control technology helps provide peace of mind in your work environment.
Collaboration
Collaborate clearly with HP Noise Cancellation Software and the optional HP Collaboration Keyboard.
Reset the performance curve
Boot up fast and quickly transition between applications with an optional powerful HP Turbo Drive G2.
Simplify device management
Reduce the complexity of administration. HP Client Management Solutions, HP Touchpoint Manager, and Dash v1.17 allow easy management of your devices.
Versatility
The HP EliteDesk 705 with its wireless antenna and integrated VESA mounts, serves a variety of use cases beyond being a desktop PC.
Solid support services
Take advantage of HP’s Elite Support, limited warranty, and Global Series support.
Create a compact, efficient workspace
Attach your HP Desktop Mini directly behind select HP Elite Displays.
Product Description HP EliteDesk 705 G3 - mini desktop - A10 PRO-9700E 3 GHz - 8 GB - 256 GB - UK layout
Type Personal computer - mini desktop
Localisation Language: English / region: United Kingdom
Processor 1 x AMD A10 PRO-9700E / 3 GHz (3.5 GHz) (Quad-Core)
Cache Memory 2 MB L2 Cache
Cache Per Processor 2 MB
RAM 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller SATA (SATA 6Gb/s)
Hard Drive 1 x SSD 256 GB - SATA 6Gb/s
Optical Storage No optical drive
Graphics Controller AMD Radeon R7
Audio Output Stereo
Networking GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, 802.11ac
Power AC 120/230 V (50/60 Hz)
OS Provided Windows 10 Pro 64-bit Edition
Dimensions (WxDxH) 17.7 cm x 17.5 cm x 3.4 cm
Weight 1.3 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - parts and labour - 3 years - on-site
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDesk 705 G3 -...
