HP EliteDesk 705 G3 SFF A series A6 PRO-9500 4GB 500GB Window...
HP EliteDesk 705 G3 SFF A series A6 PRO-9500 4GB 500GB Windows 10 Pro
£649.16
Delivery:
Key features
  • AMD PRO A-Series APUs with Radeon™ graphics deliver dependable performance for your business.
  • Extend your business investments with a long life cycle and platform stability built into a PC designed to undergo MIL-STD 810G testing.
  • HP Sure Start with Runtime Intrusion Detection monitors in-memory BIOS, recovers the platform without intervention, restores the BIOS to a custom state, and is enterprise ready for centralized management.
  • The 65W AMD Ryzen™ 3 Pro and 5 PRO CPUs or the optional 95W AMD Ryzen™ 7 PRO CPU, and high-end discrete graphics deliver powerful performance for your business.
  • Processor Type: A6
  • Operating System: Windows 10 Pro 64-bit Edition
  • Installed Memory: 4GB
  • Hard Drive Capacity: 500GB, 500GB
  • Storage Type: HDD
Product codes
The HP EliteDesk 705 delivers impressive value with uncompromising performance, security, and manageability. Customize your HP EliteDesk 705 with expandable options that provide an enterprise-class experience to meet virtually any business need.
Fit user needs and the budget
Power your PC with the latest 7th generation AMD Pro A-Series APUs and upgrade your system with up to 64 GB of DDR4 memory, the latest SSD drives, graphics, and HP accessories without breaking the budget.
Security built in
IT efficiency reigns supreme when it’s backed by comprehensive security solutions, including HP BIOSphere with HP Sure Start Gen 3, AMD Secure Processor, and TPM 2.0.
Reliability for the long haul
This work-ready PC is designed with platform stability up to 18 months for a long life cycle. Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G testing.
Pure performance and enhanced visual experience
The latest AMD PRO A-Series APUs with Radeon™ graphics deliver desktop performance optimized for diverse digital workloads and dependable daily productivity across your business.
Product Description HP EliteDesk 705 G3 - SFF - A6 PRO-9500 3.5 GHz - 4 GB - 500 GB - UK
Type Personal computer - small form factor
Localisation Language: English / region: United Kingdom
Processor 1 x AMD A6 PRO-9500 / 3.5 GHz (3.8 GHz) (Dual-Core)
Cache Memory 1 MB L2 Cache
Cache Per Processor 1 MB
RAM 4 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller SATA (SATA 6Gb/s)
Hard Drive 1 x 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage No optical drive
Graphics Controller AMD Radeon R5
Audio Output Stereo
Networking GigE
Keyboard UK
Power AC 120/230 V (50/60 Hz)
OS Provided Windows 10 Pro 64-bit Edition
Dimensions (WxDxH) 38 cm x 33.8 cm x 10 cm
Weight 6.6 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - parts and labour - 3 years - on-site
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDesk 705 G3 SF...
£649.16
