General |
Platform Technology |
Intel vPro Technology |
Type |
Personal computer |
Product Form Factor |
Mini desktop |
Built-in Devices |
Speaker, hood sensor |
Embedded Security |
Trusted Platform Module (TPM 2.0) Security Chip |
Localisation |
Language: English / region: United Kingdom |
Processor / Chipset |
CPU |
Intel Core i5 (6th Gen) 6500 / 3.2 GHz |
Max Turbo Speed |
3.6 GHz |
Number of Cores |
Quad-Core |
CPU Qty |
1 |
Max CPU Qty |
1 |
CPU Upgradability |
Upgradable |
Processor Main Features |
Intel Turbo Boost Technology 2, Intel Smart Cache |
CPU Socket |
LGA1151 Socket |
Chipset Type |
Intel Q270 |
Cache Memory |
Installed Size |
6 MB |
Cache Per Processor |
6 MB |
RAM |
Installed Size |
8 GB / 32 GB (max) |
Technology |
DDR4 SDRAM - non-ECC |
Effective Memory Speed |
2133 MHz |
Rated Memory Speed |
2400 MHz |
Memory Specification Compliance |
PC4-19200 |
Form Factor |
SO-DIMM 260-pin |
Slots |
2 (Total) / 1 (empty) |
Features |
Unbuffered, dual channel memory architecture |
Configuration Features |
1 x 8 GB |
Hard Drive |
Type |
HDD |
Capacity |
1 x 500 GB |
Interface Type |
SATA 6Gb/s |
Spindle Speed |
7200 rpm |
Storage Controller |
Type |
1 x SATA |
Controller Interface Type |
SATA 6Gb/s |
Optical Storage |
Type |
No optical drive |
Monitor |
Monitor Type |
None. |
Graphics Controller |
Graphics Processor |
Intel HD Graphics 530 Dynamic Video Memory Technology |
Video Interfaces |
DisplayPort |
HDCP Compatible |
Yes |
Max Monitors Supported |
3 |
Audio Output |
Sound Output Mode |
Stereo |
Max Sampling Rate |
192 kHz |
Compliant Standards |
High Definition Audio |
Input Device |
Type |
Mouse, keyboard |
Keyboard |
Keyboard Name |
HP Business Slim Keyboard |
Interface |
USB |
Localization & Layout |
UK |
Mouse |
Technology |
Optical |
Interface |
USB |
Networking |
Interface (Bus) Type |
PCI Express Mini Card (M.2) |
Ethernet Controller |
Intel I219-LM |
Wireless LAN Supported |
Yes |
Wireless NIC |
Intel Dual Band Wireless-AC 8265 |
Data Link Protocol |
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 4.2 |
Expansion / Connectivity |
Bays |
1 (total) / 0 (free) x internal 2.5" x 1/8H |
Slots |
1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2280 (x4 mode) |
Interfaces |
6 x USB 3.1 Gen 1 (2 front, 4 rear) (two of them with wake functionality, one of them is charging) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 1 x headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x headphones (1 in front) |
Miscellaneous |
Included Accessories |
HP Desktop Mini Vertical Chassis Stand |
Theft/Intrusion Protection |
Security lock slot (cable lock sold separately), padlock loop |
Security Slot Type |
Kensington security slot |
VESA Mounting Interface |
100 x 100 mm |
ACPI, CCC, Common Criteria EAL4+, CECP, SEPA, low halogen |
Power |
Device Type |
Power adapter |
Nominal Voltage |
AC 120/230 V (50/60 Hz) |
Power Provided |
65 Watt |
Efficiency |
89% |
Power Factor Correction |
Yes (active) |
Operating System / Software |
OS Provided |
Windows 10 Pro 64-bit Edition English |
Software |
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Systems Software Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Noise Cancellation, HP Client Security Suite Gen3, HP Notifications, HP Manageability & Integration Kit |
Environmental Standards |
ENERGY STAR Certified |
Yes |
Manufacturer Warranty |
Service & Support |
Limited warranty - parts and labour - 3 years - on-site |
Dimensions & Weight |
Width |
17.7 cm |
Depth |
17.47 cm |
Height |
3.42 cm |
Weight |
1.21 kg |
Environmental Parameters |
Min Operating Temperature |
10 °C |
Max Operating Temperature |
35 °C |
Humidity Range Operating |
10 - 90% (non-condensing) |
