HP EliteDisplay E190i 19" 1280x1024 8ms VGA DVI DisplayP...
HP EliteDisplay E190i 19" 1280x1024 8ms VGA DVI DisplayPort IPS LED Monitor
£191.44
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Find your most comfortable viewing position with customizable tilt, height adjustment, swivel, and pivot settings.
  • Get crisp, clear content and video from the high 3M:1 dynamic contrast ratio and fast response time.
  • Get great 178-degree viewing angles and stunning color integrity from In-Plane Switching (IPS) technology. Accurately view sharp images and consistent color from almost any angle—with less distortion than conventional TN (Twisted Nematic) panels.
  • Keep the 5:4 aspect ratio that your business-specific enterprise and public sector applications are designed to work with. Enjoy ample space for all your tasks on the 48 cm (18.89'') diagonal screen.
  • Personalize your workspace with resizable screen partitions and work in documents, spreadsheets, and e-mail in separate regions of the screen—at the same time—with HP Display Assistant software.
  • Reduce power consumption and help lower your costs with an intelligent, energy efficient design that’s ENERGY STAR® qualified and EPEAT® Gold registered.
  • Diagonal Size: 18.9in
  • Max Resolution: 1280 x 1024
  • Response Time: 14ms
  • Speakers: None
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
The legacy friendly, business-critical IPS display. Get a 5:4 aspect ratio display designed for all of your business-specific applications, now with the impeccable presentation and extra-wide viewing angles of IPS technology. Enjoy customizable comfort from a completely adjustable stand and be environmentally responsible with designed-in energy efficiency.
Product Description HP EliteDisplay E190i - LED monitor - 18.9"
Device Type LED-backlit LCD monitor - 18.9"
Features USB 2.0 hub
Panel Type IPS
Aspect Ratio 5:4
Native Resolution 1280 x 1024 at 60 Hz
Pixel Pitch 0.2928 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 3000000:1 (dynamic)
Response Time 14 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, anti-static
Colour Black
Dimensions (WxDxH) - without stand 41.7 cm x 4.7 cm x 34.7 cm
Weight 3 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified EPEAT Gold
Compliant Standards Plug and Play, CSA, UL, TUV, VCCI, GS, CCC, FCC, ISO 9241-307, KCC, CISPR, MEPS, KC, CECP, EuP, TCO Displays
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay E190i...
£191.44
