HP EliteDisplay E202 20" Monitor
£146.07
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect to a range of PCs and everyday devices with HDMI, DisplayPort, and VGA inputs and a USB hub.
  • Settle into your most comfortable position with adjustable tilt, height, swivel, and pivot settings.
  • Show and share projects around the room with 178-degree, wide-angle IPS technology and enjoy HD+ color and clarity for all of your content.
  • Diagonal Size: 20in
  • Max Resolution: 1600 x 900
  • Response Time: 7ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Get comfortable and be productive with the affordable, easy-to-deploy HP EliteDisplay E202 50,8 cm (20") Monitor, an HD+ IPS display that is Certified for Windows 10 and includes excellent ergonomic adjustability and crisp, clear color presentation.
Product Description HP EliteDisplay E202 - LED monitor - 20"
Device Type LED-backlit LCD monitor - 20"
Energy Class Class A
Energy Consumption per Year 26 kWh
Power Consumption (On mode) 18 W
Features USB 2.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 1600 x 900 at 60 Hz
Pixel Pitch 0.276 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 7 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - without stand 47.9 cm x 4.95 cm x 29.68 cm
Weight 2.8 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified ENERGY STAR Qualified
Compliant Standards CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay E202 2...
£146.07
