HP EliteDisplay E223d 21.5" 1920x1080 5ms HDMI DisplayPo...
HP EliteDisplay E223d 21.5" 1920x1080 5ms HDMI DisplayPort IPS LED Docking Monitor
£289.68
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Find your sweet spot with adjustable positioning. Add a second display daisy-chained through your PC’s USB-C™ connection. 3-sided micro-edge bezels ensure a virtually seamless dual-display view.
  • Maximize space in desktop PC environments by mounting your HP EliteDesk Mini Desktop PC directly behind the display and powering it through USB-C™. Or, mount the solution on a wall or arm.
  • Streamline your space with the clean, convenient cabling of one USB-C™1 connection from your notebook to a display that’s also a dock to access your devices, network, and video and power your PC.
  • Diagonal Size: 21.5in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: HDMI, USB-C
Product codes
Clear your clutter with the easy, efficient connectivity of the HP EliteDisplay E223d 21.5-inch Docking Monitor. Set up your devices and network at the display one time, then connect your notebook through just one USB-C cable and you're ready to work.
Product Description HP EliteDisplay E223d Docking Monitor - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5"
Features USB 3.1 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.274 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Input Connectors HDMI, USB-C
Display Position Adjustments Pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Dimensions (WxDxH) - with stand 48.83 cm x 20.5 cm x 44.86 cm
Weight 5.08 kg
Localisation English / United Kingdom
Compliant Standards Plug and Play, TUV GS, VCCI, BSMI, NOM, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, cTUVus, MEPS, KC, CEL, EAC, ISC, BIS, low halogen
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay E223d...
£289.68
