HP EliteDisplay E230t 23" 1920 x 1080 HDMI VGA DP IPS To...
HP EliteDisplay E230t 23" 1920 x 1080 HDMI VGA DP IPS Touchscreen Monitor
£298.36
Delivery:
Key features
  • Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display for an integrated, affordable workspace.
  • Find just the right position to be comfortable all day with adjustability that includes height up to 150 mm, tilt, swivel, and pivot, and VESA mounting.
  • Get a superb hands-on interactive touch experience minus glare and messy fingerprints with integrated in-cell touch technology that also enables a sleek, slim display.
  • Maximize your visual real estate and see even more of your work on a wide-angle display that has a three-sided micro edge screen.
Product codes
Give your productivity a hand with the ultrathin HP Elite E230t Monitor, a 23-inch diagonal Full HD IPS touch display that's Windows 10 certified with up to 10 simultaneous touch points for every way you touch and comfort adjustability for every way you work.
The next evolution of touch
Get a superb hands-on interactive touch experience minus the traditional distractions of glare and messy fingerprints with integrated in-cell touch technology that also enables a sleek, slim display.
Simply beautiful, nearly borderless
Maximize you visual real estate and see even more of your work on a wide-angle display that has a three-sided micro edge screen, which makes it easy to tile in multi-monitor arrangements and keep clean.
Create an efficient, smart setup
Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display for an integrated, affordable workspace that’s perfect for small spaces. Or, use the integrated VESA mount to place the display on a wall or stand.
Optimized ergonomics
Find just the right position to be comfortable all day with adjustable height up to 150 mm, tilt, and swivel, plus pivot rotation for portrait mode viewing. The included VESA pattern supports wall and arm mounting in tight spaces.
Featuring
Connections for your PC and USB devices
Connect to your legacy and current environments with VGA, DisplayPort™, and HDMI, and add your USB devices with the integrated two-port USB 3.0 hub.
Keep your cool
Reduce power consumption and help lower your costs with an energy-smart, EPEAT® Gold registered design.
Divide and conquer
Design the screen for how you work with HP Display Assistant software, which enables screen partitioning and helps deter theft by deactivating a monitor that’s disconnected without approval.
Make it yours
Create a complete solution with HP accessories designed and tested to work with your display.
Available and supported around the world
Help ensure a consistent worldwide deployment with a Global Series monitor that is supported by a three-year standard limited warranty.
Product Description HP EliteDisplay E230t - LED monitor - Full HD (1080p) - 23"
Device Type LED-backlit LCD monitor - 23" - touchscreen
Energy Class Class A
Energy Consumption per Year 30 kWh
Power Consumption (On mode) 20 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2652 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 500000:1 (dynamic)
Response Time 14 ms (On/Off), 5.7 ms (gray-to-gray with overdrive)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - without stand 52.08 cm x 5.23 cm x 31.195 cm
Weight 3.1 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, EAC, ISC, SEPA, low halogen, CE/EMC
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay E230t...
£298.36
