HP EliteDisplay E232 23" 1920x1080 7ms VGA HDMI DisplayP...
HP EliteDisplay E232 23" 1920x1080 7ms VGA HDMI DisplayPort IPS LED Monitor
Key features
  • Connect to your choice of PC platform and everyday devices with HDMI, DisplayPort, VGA, and USB connections.
  • Create the view that’s right for you with adjustable tilt, height, swivel, and pivot settings.
  • Enjoy sharp Full HD resolution for all your projects and collaborate easily with 178-degree viewing angles from IPS technology.
Product codes
Work smart and comfortably with the HP EliteDisplay E232 58,4 cm (23") Monitor, a large-screen Full HD IPS display with Elite-class presentation features and ergonomic adjustability for everything you do every day.
HP EliteDisplay E232 - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
54.93 cm x 18.9 cm x 54.99 cm
5.7 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, TCO Certified Edge, KC, CECP, CEL, EAC, ISC, SEPA
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay E232 2...
