We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Style meets substance in a strikingly modern business display crafted for optimal viewing, productivity, and ergonomics. The HP EliteDisplay E243 Monitor has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustability so you can comfortably power through your day.
Product Description | HP EliteDisplay E243d Docking - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class F | Energy Consumption per Year | 42 kWh | Power Consumption (On mode) | 22 W | Features | 2 microphones, 720p webcam, USB 3.1 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.2745 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Gamut | 72% NTSC, 94% sRGB | Input Connectors | HDMI, VGA, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Jack black, asteroid | Dimensions (WxDxH) - with stand | 53.88 cm x 20.5 cm x 47.71 cm | Weight | 6.1 kg | Localisation | English / United Kingdom | Compliant Standards | CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, EAC, ISC, low halogen, ICE, CEL Grade 3 | Bundled Services | HP 5 years Next Business Day Bundled Support Extension for Monitors (United Kingdom) |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Built-in Devices | 2 microphones, 720p webcam, USB 3.1 hub |
Panel Type | IPS |
Pixel Per Inch | 92.56 |
Vertical Refresh Rate | 50 - 60 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 6500K |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | HDCP, Frame Rate Control (FRC), Flicker Free technology, Mercury free, arsenic-free glass, 72% NTSC colour gamut |
Dimensions (WxDxH) | 53.88 cm x 20.5 cm x 47.71 cm - with stand |
Weight | 6.1 kg |
Connectivity | |
Interfaces | DisplayPort output (HDCP) , DisplayPort (HDCP) , HDMI (HDCP) , VGA , Network , USB-C 3.1 upstream , 4 x USB 3.1 downstream , Audio line-in , Audio line-out |
Mechanical | |
Tilt Angle | -5/+23 |
Swivel Angle | 45 |
Rotation Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x USB-C cable - 1.8 m , 1 x DisplayPort cable - 1.8 m |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 22 kWh/1000h |
Power Consumption (Typical) | 30 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | HP Display Assistant, CyberLink Youcam |
OS Required | Microsoft Windows 7 / 8.1 / 10 |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 53.88 cm - depth: 4.535 cm - height: 32.19 cm - weight: 3.58 kg , Without stand - width: 53.88 cm - depth: 20.5 cm - height: 47.71 cm - weight: 6.1 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 62 cm |
Shipping Depth | 40 cm |
Shipping Height | 27.3 cm |
Shipping Weight | 9.59 kg |
Manufacturer Warranty | |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
