HP EliteDisplay E243d Docking 1920x1080 23.8" 5ms HDMI V...
HP EliteDisplay E243d Docking 1920x1080 23.8" 5ms HDMI VGA DisplayPort USB-C LED monitor
£335.49
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Create a command center from a display and built-in docking station. Power your notebook and send and receive video over driverless USB-C™. Connect your wired network through the RJ-45.
  • Experience a virtually seamless dual-display setup with 3-sided micro-edge bezels when you daisy chain a second display from a single USB-C™ connection on your PC.
  • Reveal more of your work and support virtually seamless tiling with a 60.45 cm (23.8")diagonal IPS FHD screen and 3-sided micro-edge bezel. Daisy chain a second display from one PC with DisplayPort™.
  • Diagonal Size: 23.8in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Interfaces: DisplayPort, HDMI, USB-C, VGA (HD-15)
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £338.98
Save £1.50
Style meets substance in a strikingly modern business display crafted for optimal viewing, productivity, and ergonomics. The HP EliteDisplay E243 Monitor has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustability so you can comfortably power through your day.
Product Description HP EliteDisplay E243d Docking - LED monitor - Full HD (1080p) - 23.8"
Device Type LED-backlit LCD monitor - 23.8"
Energy Class Class B
Energy Consumption per Year 42 kWh
Power Consumption (On mode) 29 W
Features 2 microphones, 720p webcam, USB 3.1 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2745 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Input Connectors HDMI, VGA, DisplayPort, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Jack black, asteroid
Dimensions (WxDxH) - with stand 53.88 cm x 20.5 cm x 47.71 cm
Weight 6.1 kg
Localisation English / United Kingdom
Compliant Standards CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, EAC, ISC, low halogen, ICE, CEL Grade 3
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay E243d...
£335.49
