HP EliteDisplay E243i 1920x1200 5ms IPS LED Monitor
£269.35
19 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect to your most frequently-used displays and devices with a range of integrated ports right at the display.
  • Expand your productivity with uninterrupted views on a high resolution, 3-sided micro-edge bezel IPS screen that supports virtually seamless multi-display arrays.
  • Find your most comfortable, productive position with adjustable tilt, height, swivel, and up to 150 mm height adjustment settings.
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1200
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £272.84
Save £1.50
Style meets substance in a strikingly modern business display crafted for optimal viewing, productivity, and ergonomics. The HP EliteDisplay E243i 24-inch Monitor has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustability so you can comfortably power through the day.
Product Description HP EliteDisplay E243i - LED monitor - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 38 kWh
Power Consumption (On mode) 26 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:10
Native Resolution WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch 0.27 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms (On/Off)
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, anti-static
Colour Silver
Dimensions (WxDxH) - with stand 53.2 cm x 21.39 cm x 36.23 cm
Weight 6.36 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV GS, VCCI, BSMI, WHQL, CB, CCC, FCC, ISO 9241-307, WEEE, ICES, S Mark, cTUVus, ERP, CEL, ISC, RCM, MSIP, CoC, low halogen
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay E243i...
£269.35
