HP EliteDisplay E243m 23.8" HD 5ms IPS Monitor
£199.30
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Expand your productivity with uninterrupted views on a high resolution, 3-sided micro-edge bezel IPS screen that supports virtually seamless multi-display arrays.
  • Find your most comfortable, productive position with adjustable tilt, height, swivel, and up to 150 mm height adjustment settings.
  • Meet online with a Skype for Business┬« certified display with an HD webcam, expertly-tuned Audio by Bang & Olufsen, microphone, and collaboration keys to control calls without an onscreen menu.
  • Diagonal Size: 23.8in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
Connect and collaborate in complete comfort on the HP EliteDisplay E243m 60.45 cm (23.8") Monitor, which is Skype for Business certified for optimal video and audio experiences between displays and has a 3-sided micro-edge bezel for seamless multi-display tiling and 4-way adjustable ergonomics.
Product Description HP EliteDisplay E243m - LED monitor - Full HD (1080p) - 23.8"
Device Type LED-backlit LCD monitor - 23.8"
Energy Class Class A+
Features 2 microphones, USB 3.0 hub, 720p webcam
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2745 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 10000000:1 (dynamic)
Response Time 5 ms (On/Off)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Black (rear cover), silver (speakers, bezel and stand)
Dimensions (WxDxH) - with stand 53.88 cm x 21.4 cm x 51.37 cm
Weight 6.6 kg
Localisation English / United Kingdom
Environmental Standards TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
Compliant Standards Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, EAC, ISC, CEL Grade 2, low halogen, ICE, SmartWay
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
HP EliteDisplay E243m...
£199.30
