We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Help protect your onscreen data in an instant with the HP EliteDisplay E243p Sure View Monitor. It's our first 23.8" diagonal display with an integrated privacy screen that's designed to shield sensitive content from prying eyes.
Product Description | HP EliteDisplay E243p - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" - HP SureView | Energy Class | Class E | Energy Consumption per Year | 23 kWh | Power Consumption (On mode) | 18.5 W | Features | USB 3.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.2745 mm | Brightness | 260 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 14 ms (grey-to-grey) | Colour Gamut | 72% NTSC | Input Connectors | HDMI, VGA, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, anti-static | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - without stand | 53.88 cm x 4.51 cm x 32.19 cm | Weight | 3.48 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen | Manufacturer Warranty | 5-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Built-in Devices | USB 3.0 hub |
Panel Type | IPS |
Pixel Per Inch | 93 |
Vertical Refresh Rate | 50 - 60 Hz |
Horizontal Refresh Rate | 30 - 80 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Colour Temperature | 6500K |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Privacy Technology | HP SureView |
Features | HDCP, On-screen Digital Controls, Full HD BrightView, Low Blue Light Mode, Mercury free, Color Calibrated, arsenic-free glass, micro-bezel design, 72% NTSC colour gamut |
Colour | Black |
Dimensions (WxDxH) | 53.88 cm x 4.51 cm x 32.19 cm - without stand |
Weight | 3.48 kg |
Connectivity | |
Interfaces | HDMI (HDCP) , DisplayPort (HDCP) , VGA , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) |
Mechanical | |
Tilt Angle | -5/+22 |
Swivel Angle | 45 |
Rotation Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x VGA cable , 1 x DisplayPort cable , 1 x HDMI cable |
Backlight Life | 30,000 hours |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 18.5 kWh/1000h |
Power Consumption (Typical) | 40 Watt |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Included Software | HP Display Assistant |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 53.88 cm - depth: 20.5 cm - height: 46.3 cm - weight: 5.8 kg , Without stand - width: 53.88 cm - depth: 4.51 cm - height: 32.19 cm - weight: 3.48 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 64.5 cm |
Shipping Depth | 28.5 cm |
Shipping Height | 42 cm |
Shipping Weight | 9.8 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 5 years - on-site |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
